repeatedly blowing speakers
chaos7692
Member - Posts: 21
Posted: November 21, 2011 at 12:16 AM / IP Logged
A few months ago i replaced the factory dash speakers in a familly members '04 camry. They were blown, and intollerable at even low volumes. The speakers were factory rplacements due to the odd size of the opening, and mounting screw placement.   3 months after, the car was retuned with the same problem. She wants to eliminate the dash speakers and go with better door speakers. The deck is a factory gps unit, and i'm not sure what the output per channel is, i assume the dash and door speakers are on the same channel, so maybe some aftermarket door speakers will improve the sound, but i think maybe something else is going on to cause the speakers to blow again so soon. Any ideas would be appreciated.
KarTuneMan
Platinum - Posts: 7,056
Posted: November 21, 2011 at 1:05 AM / IP Logged
The uneducated listener is "blowing" the speakers.... bass at +10, as well as the treble.... (mid's too... if it has it)
and lets not forget the LOUDNESS...... it's on of course! There is not much else in a totally factory system that will cause this type of problem...
chaos7692
Member - Posts: 21
Posted: November 21, 2011 at 1:37 AM / IP Logged
Would normally be my 1st assumption, but seeing as shes 50, and she feels like her head is going to explode when listening to my stereo at low levels, i dismissed that as a possibility.
soundnsecurity
Gold - Posts: 2,720
Posted: November 22, 2011 at 1:58 PM / IP Logged
it doesnt mean that someone else doesnt use her car sometimes and turns it up all the way.
DYohn
Platinum - Posts: 10,741
Posted: November 23, 2011 at 12:19 PM / IP Logged
A factory head unit that blows factory speakers is likely defective.  Get the head unit tested.
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
