Boss Elite Radio Not Raising Power Antenna, 1995 Cadillac DeVille
stargaizer
Member - Posts: 11
Posted: January 18, 2025 at 8:13 PM / IP Logged Link to Post Post Reply Quote stargaizer
Hey guys,
Just installed a new boss audio systems elite model BE9ACP floating touch screen radio, install overall seems to work but one issue, the radio is not raising my car's power antenna, reading through the manual it says the output is max 500mA @ 12v but when measured the output is .1xx volts, is there a hidden setting or perhaps something I did wrong, worked just fine with the Delco radio before replacement.
1995 Cadillac DeVille 4.9L Base
Thanks!
Stargajzer
Platinum - Posts: 13,714
Posted: January 19, 2025 at 9:38 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Disconnect the wire from the car and check voltage on the wire coming from the radio. If there is 12 volts on it now, the cars circuit may draw more than the radio can handle. If you do have 12 volts on that wire with no load, you can simply add the following relay setup to make it work.
https://www.the12volt.com/relays/relaydiagram25.html
Thursday, July 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
