Ground loop?
704acc
Copper - Posts: 55
Posted: May 09, 2005 at 11:49 PM / IP Logged
Years ago I saw an install where a 6" wire of smaller guage was attached to the chassis grounding point for the amps, then grounded to the chassis 2" away.   The installer said this ground loop eliminated alternator noise.
Was he jerkin' my Gerkin?
Ray Kane
lasergrad2001
Member - Posts: 7
Posted: May 10, 2005 at 12:19 AM / IP Logged
I don't see how that would "eliminate" alternator noise, but I could be wrong.  I would just make sure that you have all you amps ground to the same point
DYohn
Platinum - Posts: 10,741
Posted: May 10, 2005 at 8:22 AM / IP Logged
I can't say for sure without seeing exactly what was done, but from what you wrote I'd bet yer gerkin was jerked.
tcss
Silver - Posts: 1,623
Posted: May 10, 2005 at 7:39 PM / IP Logged
A ground loop is caused when the amp is seeking ground some where other then the ground wire. A corroded ground connection could cause the amp to seek ground thru the RCAs or where the amp is mounted. A better way to insolate the amp is to put plastic washers between the amp and the mounting point. What this guy was doing would allmost enhance the chance of a ground loop! Consider thy gerkin offially jerked.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
