Two 12's vs. one 10 sub
Arqi
Posted: August 04, 2005 at 1:55 PM / IP Logged
I have two 12 inch Sony XPLOD (XS-L1236) wired to a Fosgate 700s amp. Is there any one 10 inch sub that will hit as hard as the two 12's that I have or close to it using the same amp? I am looking for more SQ and also to save space and weight in the trunk. My budget is around $200; I can go a little higher but lower is better.
Thanks guys
Bigsingh
Copper - Posts: 204
Posted: August 04, 2005 at 3:34 PM / IP Logged
you will certainly achieve better sq with one ten due to the reduced weight of the cone and other stuff. but hitting hard enough i'm not sure but seing as that we're looking at sony's you will probably be able to get sumthing for around $180 that could pump harder, not sure what though
6* Rockford T2's
6* POWER AMPs
BLACK CORRADO
BAANNGGIINN
mrmsudawgs
Copper - Posts: 145
Posted: August 04, 2005 at 5:07 PM / IP Logged
Use WinISD to simulate what you want. You can compare the two 12s to one ten - no problem.
Mike
2000 F150 Supercab Lariat, Alpine CDA-9831, Polk MMC570 in Doors, One Polk MM2104 Sub, One Polk Carbon C400.4 Amp.
John 3:16
Arqi
Posted: August 04, 2005 at 6:24 PM / IP Logged
Thanks for the fast response guys. Would you know of any brand/model? According to the spec sheet for my amp I can push 700 watts rms bridged 1 channel, would this be enough for what I want?
Blowntweeters
Silver - Posts: 650
Posted: August 05, 2005 at 12:28 PM / IP Logged
checkout www.ikesound.com there is some subs there that can handle that power and fit in your budget
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
Blowntweeters
Silver - Posts: 650
Posted: August 05, 2005 at 12:43 PM / IP Logged
`take a look at the alpine 1042d
Paradigm
Silver - Posts: 284
Posted: August 05, 2005 at 1:11 PM / IP Logged
This is highly misleading. That's like saying you can run faster than me because you weigh less than me (although my legs may be longer or stronger than yours). There are other factors involved besides weight that effect the SQ of a subwoofer. Two 12's vs. one 10 sub -- posted image.
VEHICLE: 2002 GMC Sonoma ZR2
Alpine CDA-7940
AudioControl EQT x2
JL Audio 1000/1
JL Audio 10W6 (originals) x3
Kicker ZR120
Kicker ZR460
Polk GXR-6 x4
Polk GXR-4 x2
sedate
Silver - Posts: 1,173
Posted: August 05, 2005 at 6:54 PM / IP Logged
Arqi:
Hmm.
Yes, you *can* get a 10 that will hit as hard two *Sony* 12's ... but certainly not for $200... or even a little more.
A 10" sub that can ... as far as output is concerned .. compete with 2x12's ... is going to be a sub on the level of the JL W7 ... simply not something you'll be able to get for $200.
For $200 could you try a single 12"? That'd give you a ton more options..
As far as the 10" for that price? I'd look at something like this.
Ultimately, Sony subs or not, you'll have a *hard* time getting a single 10 that will hit as hard as a pair of 12's... for any price.
Arqi
Posted: August 06, 2005 at 1:46 PM / IP Logged
I was looking into JL 10W7 and it has a lot of good reviews, but it’s around $500. Maybe I should raise my spending limit Two 12's vs. one 10 sub -- posted image. .
Here is the list of subs that I am looking at. I would like your opinions on the subs I picked.
Rockford Fosgate T210d2 $649.99 800WRMS
JL 10W7 (Thanks sedate) $500.00 500WRMS
Alpine Type-X SWX-1042D $399.99 1000WRMS
Audiobahn AW1006T       $249.99 900WRMS
I am not sure about the Audiobahn, it seems that it’s an all looks sub but I did find good reviews on it. Most of the prices here are from Crutchfield, I am sure I can find them cheaper if I look around. Any 10 inch subs not on the list you guys recommend? Thanks a lot guys.
elbee12
Member - Posts: 17
Posted: August 06, 2005 at 8:10 PM / IP Logged
Infinity Kappa DVQ from Car Domain approx.  $249.00 look for cheaper price anywhere and they will match it not only that but u get 3 year warranty and they can be trusted. I just received my two tens in the mail, have not heard yet but i saw some good reviews. If you want to save space 1-10" kappa DVQ fits in a .3 cu ft. enclosure thats why  i got  them
