Sub Enclosure Bracing
ace_ram
Member - Posts: 17
Posted: October 15, 2005 at 7:32 PM / IP Logged
I have an odd shaped ported enclosure(L-shape 1.80+ cu. ft internal volume). Will bracing each panel of the enclosure with 2"x2" triangular brace be enough? I'm planning to brace every side of each panel every 4 inches if applicable..
DYohn
Platinum - Posts: 10,741
Posted: October 16, 2005 at 9:50 AM / IP Logged
I'm not quite sure what you mean, but in general the more bracing the better.  The best thing to do is get braces in that connect all interior walls with one brace.  I have also seen exterior bracing used on odd shaped enclosures.
ace_ram
Member - Posts: 17
Posted: October 16, 2005 at 1:05 PM / IP Logged
Triangular braces on every wall, not one brace on the interior walls.. do you think this is effective?
DYohn
Posted: October 16, 2005 at 1:12 PM / IP Logged
Triangular braces.  What is that?  Are you talking about little triangles to connect the two walls at a corner, or a long triangular piece that runs along the seam, or what?  In any case, yes it can be effective.  No it's not as affective as connecting opposite walls and top and bottom.
ace_ram
Member - Posts: 17
Posted: October 16, 2005 at 2:38 PM / IP Logged
yup, small rectangular pieces..
