magic box that boost the alternator?
qmw54
Copper - Posts: 54
Posted: November 21, 2005 at 10:29 PM / IP Logged
one of my friends was tellin me that the reason his lights dont dim is because he bought this "box" that boost the alt. from a audio store ???? what could he be talking about  and do they work ??? and one other thing does it make a diff. in sound if you downfire your subs rather then upfire or put them facing foward and if so how much diff.
thanks qmw54
ragoal12
Copper - Posts: 135
Posted: November 21, 2005 at 10:45 PM / IP Logged
about the only thing the "box" could be is a voltage regulator... never used one on a stock alternator so they may work..... and subs that r downfired will sound louder than forward firing subs... but don't buy the "box" just buy a good HO alt if u need one...
S.O.B custsoms.. South Omaha, Nebraska
menace2sobriety
Silver - Posts: 394
Posted: November 22, 2005 at 12:01 AM / IP Logged
a step-up transformer maybe? and most alts have voltage regulators in them. some are external. but you have to have one or your alt will run wild and burn things up. but i cant see a step-up transformer help from making the lights dim. can you get a pic of that "box"
jstruckman
Copper - Posts: 465
Posted: November 22, 2005 at 9:21 AM / IP Logged
He is probably just talking about a capacitor, nothing magical about those. And downfiring subs are not always louder than front firing subs. It will depend on your box and what vehicle you are working with.
Jazzy
youngone
Silver - Posts: 269
Posted: November 22, 2005 at 10:09 AM / IP Logged
from my expeirience i have found out that downfireing subs arent louder they gust have better sq and there is less crosscansulation because it uses the floor panal as a wall so the sound goes in all directions instead of being faced towereds the back so the sound goes and hites the back and bounces forword. so there is a more evenly distributed sound wave. and it also seems to have less standing wave i dont no that for sure though.magic box that boost the alternator? -- posted image. i also THINK that since it is faceing downwords that gravity takes some of the staren of the sub so it is easyer for it to move downwords but very little. and pointing a sub upwords is not a good idea because you loss db. but if it is the only way then you sould go ahead and do it. i think that facing a sub downwords is a good idea but i like to be able to see my subs so i face them forwords. if i was going for sq then i probibly would do it.
and were is this box located, how is it setup, and a name or serial number, model number would be helpful. there are to many things it could be.
Aaron
Want to know some good equipment- JL,Adire Audio,Mcintosh,Brax,Helix,Eclipse,JBL,RE,Dimoand Audio,Zapco, pritty much anything DYhon,Forbidden recommend
On the12volt you give some info and you get in
DYohn
Platinum - Posts: 10,741
Posted: November 22, 2005 at 10:42 AM / IP Logged
Wow, where to begin... most of that is wrong information.  First, do a search for "woofer sag" and you will find a thread discussing how to determine if a woofer can be used up or down firing.  Second, there is no "loss of db" when up-firing nor is there some sort of gravity aid if down-firing.  This is nonsense.  Both up and down will place the same strain on a woofer.  Some can handle it, some can't and the loudness and SQ has nothing to do with how it's mounted all by itself, it has to do with overall system design.
The direction a sub should face is determined by three things: first, the vehicle and what works best in it (and every one is different.)  Second, the woofer and how is is designed to be mounted.  Third, the requirements of the installation and the intended system design.  All three must be considered for proper woofer and enclosure choice.
tcss
Silver - Posts: 1,623
Posted: November 22, 2005 at 11:43 AM / IP Logged
DYohn you must get to work before me. You beat me to it on this one.
There is no such thing as free installation!
sedate
Silver - Posts: 1,173
Posted: November 22, 2005 at 1:18 PM / IP Logged
Ya know recently someone posted a link to a *really* good couple of pages that featured some guy with like $5K worth of oscilloscopes and mics and computer sound software and he did like this crazy experiment trying to figure out exactly how sound waves work with cars' in various stages of setup... like one series of measurements of the trunk closed, seats back, one with the trunk open and the seats closed, one with everything closed.. all kinds of stuff.
Really informative stuff...
Anyone know what I'm talking about or what happened to that link?
sedate
Posted: November 22, 2005 at 1:31 PM / IP Logged
Oh yea.. back the topic of "magic boxes" ... I once heard about a guy using an Alumapro 5 farad CAP to reinforce.. get this.. not his sub-amp.. but his cars' electrical system. Like, he ran the thing to the wiring harness of this cars battery, not back in the rear with amps.
Of course, this brings up another bug-a-boo I've never gotten real straight on: the proper behavior of DC current.. some people akin it to water.. more pressure in certain parts of the system than others correlating to demand... this logic leads us to conclude that the CAP would work well in this situation.. the CAP between the lights and battery, instead of the amp and battery, would reinforce the lights no? DCs' transmission/distance difficulties would support this line of thinking ... ?
Others akin it to a unified system.. a voltage drop somewhere in the circuit is a voltage drop everywhere.. since electrically speaking, the circuit all looks like the same 'point' ... this logic would lead us to conclude that a CAP at that stage of the electrical system would be just as effective.. or ineffective.. as a CAP sitting 2 inches from the amp it is meant to reinforce.
pss5075104
Copper - Posts: 144
Posted: November 22, 2005 at 1:41 PM / IP Logged
he might have a batcap.
D
MECP First Class Certified Installer.
Nothing is impossable, it's just more expensive.
Page of 3
Sunday, January 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
