best way to hook up 4 10 subs
xkuco
Member - Posts: 29
Posted: April 07, 2006 at 4:28 PM / IP Logged
im trying to hook up 4 10 inch pioneer ts-w251r subs in my show car but not very fond of hooking up subs i would like to know what amplifier would u guys recomend like make and model and why it would really help and how exactly or the best way too hook it up : on a side note itts gonna be in a custom fiberglass box im building thanks
xkuco
Member - Posts: 29
Posted: April 08, 2006 at 9:55 AM / IP Logged
i just would like the best way to hook it up any recommendations??
xtremej
Gold - Posts: 1,440
Posted: April 08, 2006 at 10:11 AM / IP Logged
best way to hook up 4 10 subs -- posted image.
xtremej
Gold - Posts: 1,440
Posted: April 08, 2006 at 10:14 AM / IP Logged
Couldn't remember if those were single voice coils or doubles, rough night. hope this helps.
hardknocks
Member - Posts: 39
Posted: April 08, 2006 at 10:36 AM / IP Logged
there are a lot of good two channel D class amps the at are out there.
rockfordfosgate.com
planetaudiousa.com
soundstream.com/amplifers
JLaudio.com
DEI.com   (they make viper, directed,orion amps  )
crossfire
audio pipe
diamond audio ( they are a new line of audio equipment)
being this sub is rated at 600watts max i would get 2 600watt D class amp and have 2 on each amp . the links are to just a few amps that would be great for you.  hope this helps u out .
4-15" RF T2
6-7" RF Component sets
8 Planet Audio 900d
10 Batcap800
1 250 amp alt
1 300 amp alt
2" sound deadner roof,doors,floors
xtremej
Gold - Posts: 1,440
Posted: April 08, 2006 at 10:54 AM / IP Logged
You can also look at concepts I just picked up there line I've installed quite a few and they perform awesome and they aren't very exspensive compared to most. Xtreme by DEI also perform decent to but they are a tad overated.
xkuco
Member - Posts: 29
Posted: April 08, 2006 at 11:21 AM / IP Logged
im looking to keep the whole pioneer theme this is show memeber its not like just a car lol but that did help xtreme but i still would like to know if i put two amps two for each how would the set up be and what pioneer amp would u recommend thanks guys u guys have helpped alot
Aruman
Silver - Posts: 363
Posted: April 08, 2006 at 11:33 AM / IP Logged
"there are a lot of good two channel D class amps the at are out there"
Class D amps are not 2 channel, they have 2 terminals for connect more subs, but they are not 2 channel amps.
and don't look at Max Wattage, look at Rms Wattage. those pioneer ts-w251 are 120 watt rms, 4ohm single voice coil. 4x 120= 480 watt rms tot. look for an amp that is 500 watt rms at 1ohm and wire them as the second diagram that xtremej posted before, and you should be fine
Shaking The Neighborhood
xkuco
Member - Posts: 29
Posted: April 08, 2006 at 11:37 AM / IP Logged
tru thanks mann thats cool thanks that helps alot so now all i have to do is look for a pioneer amp with 500 watts with 1 ohm but do i need a capicitor at all and also ( a newb question ) what exactly does a capcitor do and again would i need one ???
xtremej
Gold - Posts: 1,440
Posted: April 08, 2006 at 11:39 AM / IP Logged
Pioneer  GM-510M Class d mono bloc, 300X1 @4 ohm, probably need 2 but it'll keep the Pioneer theme going. These amp are pretty good, I've installed a few of the 7200M's and they  performed good minimal heat up.  the 510's have a samll footprint so they won't take up a ton of room. the 510 rates at 500X1 @ 2ohm. I don't see any amp listed stable @ 1 ohm though.
Page of 4
