Posted: October 17, 2006 at 3:56 PM / IP Logged
Posted: October 17, 2006 at 4:40 PM / IP Logged
Posted: October 17, 2006 at 5:18 PM / IP Logged
Posted: October 17, 2006 at 5:40 PM / IP Logged
Posted: October 17, 2006 at 7:11 PM / IP Logged
Posted: October 17, 2006 at 7:23 PM / IP Logged
Posted: October 17, 2006 at 7:54 PM / IP Logged
Posted: October 17, 2006 at 7:55 PM / IP Logged
Posted: October 17, 2006 at 8:08 PM / IP Logged
Posted: October 17, 2006 at 9:44 PM / IP Logged
Tuesday, May 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I was just trying to explain to oxygen65 that not all 2ohm loads will sound the same or have the same audible result. I agree with you, it all depends on the model and brand of the subs.
Flakman:
Please don't think I'm picking on ya, I'm really not. But I just realized that in order for your "all things being equal" to work, the example would be better using 2 4ohm SVC's and comparing them to 1 4ohm DVC.
That way not only is the total ohm rating (2ohms) going to be the same, but so is:
1) The total number of voice coils (2 voice coils for each example instead of 2 voice coils combined for the SVC's and 4 voice coils combined for the DVC's.
2) The ohm rating for each coil will be the same (4ohms per coil)
3) The wiring methodology will be the same for both examples (instead of Parallel for the SVC's and Series/Parallel for the DVC's)
