Anything to worry about with this setup
xorphan
Member - Posts: 15
Posted: December 08, 2006 at 2:24 PM / IP Logged
i've purchased and am about to install my 4000 w 2ch amp
with 2 15" subs At 2000 w peak, but i'm only installing one sub for now.
i'm going to use a line output converter and tap into the front door speaker, and add a volume control.
do i need to worry about dimming lights or any other unwanted issues with my setup...?
xorphan
Member - Posts: 15
Posted: December 08, 2006 at 2:26 PM / IP Logged
might i add, i have the chrysler 300c 2006
haemphyst
Platinum - Posts: 5,059
Posted: December 08, 2006 at 3:03 PM / IP Logged
Ummm... Audiobahn, right? If so, the answer to your question is "Yes."
Suggestion - return all of that stuff, and buy some real equipment, maybe not as "high powered" as those outlandish claims, but respectable and real power for about the same money. Audiobahn is garbage, and you will not hear many (if ANY) people disagreeing with that statement here on this forum...
I would look into an HO alternator, and upgrade all of the power cables under your hood.
aznboi3644
Gold - Posts: 2,600
Posted: December 08, 2006 at 4:37 PM / IP Logged
And battery ground cable lol...forgot that haem
forbidden
Platinum - Posts: 5,354
Posted: December 08, 2006 at 7:57 PM / IP Logged
Sounds more like MA Audio crap to me or some other flea market variety. Then again could it be some uber high end gear?
coppellstereo
Silver - Posts: 785
Posted: December 08, 2006 at 8:10 PM / IP Logged
what are the specs on the amp?
cmrs2k
Member - Posts: 16
Posted: December 08, 2006 at 8:40 PM / IP Logged
If the amp really does put out 4000 watts, you will need to be thinking about alternator upgrades and an additional battery or batteries.  Most of the amplifiers that I know of that ratings like that won't come close to actually doing it.  I'm not saying that there aren't amps that will, but just not very many.
Chris R.
cmrs2k
Member - Posts: 16
Posted: December 08, 2006 at 8:43 PM / IP Logged
Sorry, I meant an alternator upgrade.  Also, If you are talking about the previously mentioned brands: Lanzar, Pyle, MA, Audiobahn, etc.  They probably won't do anything near what they say they will.
Chris R.
kirktcashalini
Silver - Posts: 492
Posted: December 09, 2006 at 10:33 AM / IP Logged
If it were the "uber high gear" he would not have posted, and he would have mentioned RMS watts. not peak, take the MA or audiobahn/pipe crapola out of your mind, and get some real RMS watts. even somehting like 400-600RMS will probably be clearer and more powerful than a 1134690346 watt audiobahn amp and subs.
xorphan
Member - Posts: 15
Posted: December 09, 2006 at 2:49 PM / IP Logged
Rockford Fosgate T40001bd
4000 Watt Class-bd Mono Amplifier
MSRP $2,799.99
CEA-2006 Compliant
Number of Channels      1
Rated Power
2000 W x 1 @ 4 Ohms RMS
3000 W x 1 @ 2 Ohms RMS
4000 W x 1 @ 1 Ohm RMS
Total Power      4000 Watts RMS
Bridgeable      Yes (bd-sync2 cable required)
MasterSync
PowerSync
Crossover Controls      Low-Pass (LP): 32-250Hz 24db/octave Butterworth
Infrasonic filter: 27Hz 12db/octave
Tone Controls      Bass: 0dB to +18dB @ 35-70Hz
Phase: 0/180 degrees
Signal Input      Low level: 1 RCA pair
Signal Output      Low level: 1 RCA pair
Power Input Connector      Block
Power Wire Gauge      1/0 AWG
Speaker Output Connector      Screw terminal barrier strip
Speaker Wire Gauge      8 AWG to 18 AWG
Heat Sink Type      Cast aluminum
Cooling      Fan cooled
Remote Controls      ParaPunch Bass EQ (included with cable)
Visual Indicators      Power On
Thermal Status
Speaker Protection
Circuit Topology Class      Class bd
Frequency Response      20Hz to 300Hz +/- 0.5 dB
Dimensions      2.6 x 12.8 x 33 (in)
6.6 x 32.5 x 83.8 (cm)
Shipping Weight      TBA Lbs.
(TBA Kg.)
