2003 liberty cd changer problem
jihadmatar
Member - Posts: 8
Posted: February 23, 2007 at 8:51 AM / IP Logged
hello guys,
a 2003 liberty (oem) is stuck. i couldnt reset it from cd chnager itself. and the radio says error when you try to use cd changer. any info will be greatly appreciated.
jay 2003 liberty cd changer problem -- posted image.
master5
Silver - Posts: 1,123
Posted: February 23, 2007 at 10:03 AM / IP Logged
A factory changer generally does not have a reset button. What you can try for giggles is to reset it by unplugging the changer itself for a few minutes and then plug it back in and try it. If for some reason you can't get to the changer plug you can also reset it by disconnecting the battery for a few minutes as well.
If this doesn't work and you are daring enough you can remove the changer and start taking it apart (several tiny screws usually) and try to manually eject the cartridge..but be careful not to bend or break anything or it's all over. Reassemble if you free it and test it out.
If this doesn't work it is time for a repair or replacement of the changer..they do go bad unfortunatly..like any other electrical part with all kinds of mechanisims in it.
jihadmatar
Member - Posts: 8
Posted: February 23, 2007 at 11:04 AM / IP Logged
thank you so much for your help.
jay
master5
Posted: February 23, 2007 at 12:25 PM / IP Logged
you're welcome
