amp fuse keeps blowing
shezza
Member - Posts: 42
Posted: October 21, 2007 at 6:02 AM / IP Logged
Hey guys,
Newbie here... I was installing a amp and subwoofer today and I bumped into a problem. I wired the amp with 4 Gauge wiring from the battery, with a earth from the body and the remote from the previous remote I had connected for my last amp (which was connected to my rears) to a accessories wire (live). Everytime I connect the final wire, I get some nice fireworks coming from where Im connecting it and then the fuses blow. I put a test light between the earth connection and the earth wire and it stopped the fuse from blowing. So Im pretty lost as to where I go from here. Any ideas? While I got the post up, any opinions on soundstream subwoofers and alpine splits? My bro wants to sell them to me.
Cheers in advance
ice32
Copper - Posts: 116
Posted: October 21, 2007 at 7:21 AM / IP Logged
so it works properly with the test light between the earth connection and the earth wire? or does it just stop the fuse from blowing?
shezza
Member - Posts: 42
Posted: October 21, 2007 at 8:30 AM / IP Logged
Well... it only sort of worked, not fully. Subby didnt work.Anyway, I cleaned up the earth connection and it worked. No sparks... the subby was going, i was smiling and then... nothing :S The fuse at the battery blew and it wasnt a once off as it happened the second time too :SGet past one problem, hit head on with another :(
DYohn
Platinum - Posts: 10,741
Posted: October 21, 2007 at 10:27 AM / IP Logged
It's hard to say what's going on but it could be a bad ground for the amp, or even a defective amp.  One note: you should always disconnect your battery when working on your power system, which prevents "fireworks."
techman93
Silver - Posts: 591
Posted: October 21, 2007 at 11:06 AM / IP Logged
It sounds as though the amp could have an issue with internal components. It is a rule of thumb to connect ground to device then the power. Remote should be a 12v+ switched from radio power antenna wire or amp turn on wire. Then once these wires are connected, that is when you insert fuse at battery.
shezza
Member - Posts: 42
Posted: October 21, 2007 at 7:10 PM / IP Logged
I think I follow the same rule of thumb... Negative off first, on last. As for it being a bad ground, I screwed it to a existing thread in my boot. I sanded back the paint and I dunno... I wish there was a way to test a ground (without some fancy equipment). Im doubtful its the amp... but I will try connecting up my other amp and Ill report back as to how it goes. Off to work now. Cheers guys.
tedmond
Gold - Posts: 4,610
Posted: October 21, 2007 at 7:30 PM / IP Logged
do this, ground off batt terminal FIRST
1)clean up the place (paint. rust proofing, etc) where you wish to ground your wire.
2)Ground the wire securly.
3)Pull out our head unit, look for a BLUE wire. Usually that is the remote turn on lead or antenna trigger. Run a new wire or exising one again to the back or where your amp sits
4)connect rca cables, put back deck and connect your 12 volt line WITHOUT FUSE
5) Reconnect ground, then add fuse to the wire from batt to amp. Turn on your deck and see if your amp turns on without blowing fuses.
ice32
Copper - Posts: 116
Posted: October 21, 2007 at 8:42 PM / IP Logged
I dunno what the pros have to say about this but, i test my ground by getting a multimeter and placing one prong on the + and one on the - of the battery once i've found out my battery reading (around 12v).
Then i find a 12v source in the car (e.g amp power lead) put the positive prong on that and then put the negative prong on where i plan to ground and see what the reading is, if its the same as the battery reading its a good ground if its not the same by a pretty reasonable amount then i put it down to bad ground.
jazzcustom131
Copper - Posts: 175
Posted: October 22, 2007 at 3:34 AM / IP Logged
Yes, a multimeter is about as fancy as is necessary (though I'm sure you could get more fancy).
shezza, take tedmond's list, and do what ice32 said to before completing the second step...
if it still does it, i'd sit with DYohn on it being a bad amp... Calling the manufacturer to let them know what's goin on and sending it back for them to double check things never hurts
Greed is for amateurs.
Disorder,chaos,anarchy now THAT is fun!!
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
