400 watts, amp, woofer wiring
viperxp45
Member - Posts: 6
Posted: December 10, 2007 at 9:57 PM / IP Logged
ok i hqave a 2 channel amp. and 2 10" subwoofers at 400 watts my amp can do 480 watts at 2 ohm.
Q: do you add the 400 watts x 2 = 800 watts or is it just 2 =400 watts subwoofers. im not sure wich! do i wire it mono or do i wire it like 1 channel for 1 sub and the other channel for the other sub. the subwoofers are DVC type
Amp
Alphasonik cha150
Subwoofer
Alphasonik psw410
2nd Q:
i have a volt meter and a bass volum control both of wich have a rj11 type connector. but its not a rj11. they are smaller. i have contacted alphasonik. but they couldnt tell me what type .. they did say its a tiffny style.4 wire .. i have chwecked at radio shack . no luck..
thanks in advance steve
01trublugt
Copper - Posts: 112
Posted: December 11, 2007 at 10:00 AM / IP Logged
Are you sure about the model # on the amp?? I can't find anything on it.
As for your speakers, they are both 4ohm DVC's so you can either wire each sub to be 2ohms or 8 ohms, then connecting both to 1 ch of the amp you will either get a 4ohm load or a 1 ohm load.
Can your amp handle a 1 ohm load?
What are the specs on it is it 1ch, 2ch?? is the 480w @ 2ohms per channel or for a single bridged channel?
jl.w7
Copper - Posts: 59
Posted: December 11, 2007 at 10:17 AM / IP Logged
at a 2 ohm load your amp will produce 480 watts x1 mono, if you run one channel to one sub and one to the other, you will be getting 240 watts to EACH sub at 4 ohms. just make sure you wire your subs paralell if you go to 2ohms :)
MECP Certified
(2)Infinity 3.5" 3012CF
(2)Infinity 6x9 9612I
(1)Sony CDXGT710
(2)MTX TC510 and,
A load of dynamat!
1982 Chevy Cavalier
viperxp45
Member - Posts: 6
Posted: December 11, 2007 at 10:22 AM / IP Logged
well this is the model next to mine. mine is a 150. here is the link. and thank you for your reply.
http://www.alphasonik.com/pmahighcurrent.html
PMA300HCA
2-CHANNEL
HIGH CURRENT AMPLIFIER
150 Watts x 2 @ 4Ù Stereo
270 Watts x 2 @ 2Ù Stereo
450 Watts x 2 @ 1Ù Stereo
475 Watts x 1 @ 4Ù Mono
780 Watts x 1 @ 2Ù Mono
900 Watts x 1 @ 1Ù Mono
Dimensions (W x H x L)
9 1/16 x 2 5/8 x 16 1/16”
viperxp45
Member - Posts: 6
Posted: December 11, 2007 at 10:27 AM / IP Logged
and also .. to get the most out of this amp. wiring it paralell  is this both coils wired mono?. coz im really wanting to get the full 480 watts. to both sub. more power .. hehe i just dont want to be under watts. coz i think that would be bad too right?i may end up buying another amp. i would like to see 400 watts to each speaker. thanks in advance
jl.w7
Copper - Posts: 59
Posted: December 11, 2007 at 10:39 AM / IP Logged
yes, wire the positive from the amp to the positive of one voice coil on one sub , and then to the positive of the same voice coil on the other sub. do the same with the negative, from amp to one vc then to the other vc. that will give you a 2 ohm load = 480watts to each sub = getting the most out of your amp.
MECP Certified
(1)Sony CDXGT710
(2)MTX TC510 and,
A load of dynamat!
1982 Chevy Cavalier
01trublugt
Copper - Posts: 112
Posted: December 11, 2007 at 10:40 AM / IP Logged
Well if yours is right below this one then I am guessing yours would run the following:
75x2 @ 4ohms Stereo; 135x2 @ 2ohms Stereo; 225x2 @ 1ohm Stereo; 292 x1 @ 4ohms Mono; 480x1 @ 2ohms Mono; 550x1 @ 1ohm Mono
I would run both the subs @ 2ohms, which is done by hooking both + terminals on each speaker together and both - terminals on each speaker together, then run both speakers parallel to the amp to give you a 1ohm load on a mono channel.
jl.w7
Copper - Posts: 59
Posted: December 11, 2007 at 10:44 AM / IP Logged
how would that give you a 1 ohm load? he has dual 4 ohm voice coils, parallel would be 2 ohms.
MECP Certified
(1)Sony CDXGT710
(2)MTX TC510 and,
A load of dynamat!
1982 Chevy Cavalier
viperxp45
Member - Posts: 6
Posted: December 11, 2007 at 10:52 AM / IP Logged
ok im sorry its 450 watts.
thanks  jl.w7 and 01trublugt
here are my specks
Technical Specification :
 * RMS Power Range : 75-450 Watts
* Number Of Channels: 2
* Low Frequency response: 5 Hz
* High Frequency Response: 50000 Hz
* Built In Crossovers: Yes
* Channel Separation: Yes Features
* 75 Watts x 2 @ 4 ohms Stereo
* 140 Watts x 2 @ 2 ohms Stereo
* 200 Watts x 2 @ 1 ohms Stereo
* 240 Watts x 1 @ 4 ohms Stereo
* 350 Watts x 1 @ 2 ohms Stereo
* 450 Watts x 1 @ 1 ohm Mono
* Dimensions: (W x H x L) 9" x 2 5/8" x 12 1/4"
* Bridgeable * Hour Meter
* Remote Mount Digital Voltmeter(included)
* Heavy Duty One-piece Extruded Aluminum Heat Sink
* Beveled Clear Acrylic Protective Cover
* Tiffany-Style Input and Output RCA Jacks
* Parallel Line-out RCA Jacks
* Removable Covers Conceal Control and Terminal Panels
* MOSFET High Speed Switching Power Supply
* THD: 0.05 * Signal-to-Noise Ratio: >100dB
* Frequency Response: 5Hz~50kHz
* Input Impedance:10K ohms
* Input Sensitivity: 200mV~8V
* 4-Way Protection Circuitry: Thermal, Short Circuit, Overload and DC Offset
* On Board Hook-Up Terminals
* Thermal Cooling Fan.
im running this on a alpine 7894. bulit in watts 240. i have a enclosed box 10" by pass , I have 2 10 " alphasonik speakers
here are the specs
http://www.alphasonik.com/400.html
PSW410
10” ALPHA 400 SERIES SUBWOOFER
Heavy Gauge Stamped Steel Chrome Plated “Alpha” Basket
Motor Assembly Heat Sink
High Rigidity Inverted Dome Mineral-Filled Composite Cone
EPDM Surround for Enhanced Control at Extreme Temperatures
Flat Progressive Rate Nomex® Damper w/ Spiral-Woven Leads
8-Gauge Lug-Lock Input Terminals
Rated at 400 Watts RMS
90dB Efficiency
Frequency Response of
30Hz to 500Hz
46 oz. Double-Stacked Magnet
Dual 4-ohm 2” Voice Coils
Mounting Dimensions
Depth: 5 1/2”
Through Hole: 9 3/8”
Diameter: 10 15/16”
it looks like i have to wire it mono.. duno how tho.. you guys are great for tring to help me..
01trublugt
Copper - Posts: 112
Posted: December 11, 2007 at 10:54 AM / IP Logged
Simple Math lol
He has 2 4ohm DVC subs, so you are looking at a total of 4 4ohm coils, 2 per speaker.
If you wire the 2 4ohm coils on speaker 1 in parallel, and the 2 4ohm coils on speaker 2 in parallel, you will now have 2 2ohm speakers. If you run both speakers in parallel to the amp you now have a 1ohm load on the amp, this would get the max power out of the amp.
