Bike's charging capacity
radarcontact
Copper - Posts: 54
Posted: May 29, 2015 at 8:28 PM / IP Logged Link to Post Post Reply Quote radarcontact
Ok, so if my bike has a charging capacity of 448 watts, and I want to convert that to figure out how many amps it can handle, do I use:
I(A) = P(W) / V(V) -- So amps are equal to watts divided by volts
If that's right, and I do the math, I come up with ~37 amps at 12v and ~32 amps at 14v.
That seems wrong to me (a layman), because it seems like the more volts my bike is putting out, the MORE amps it should be able to "run".
Somebody set me straight, please.
Thanks so much!
Radar
RadarContact
radarcontact
Copper - Posts: 54
Posted: May 29, 2015 at 8:29 PM / IP Logged Link to Post Post Reply Quote radarcontact
Just FYI:
2007 Yamaha Stratoliner Midnight
RadarContact
icearrow6
Copper - Posts: 497
Posted: May 30, 2015 at 5:13 PM / IP Logged Link to Post Post Reply Quote icearrow6
Your math is correct.
If the P(watts) doesn't change, the amps of the system to drive the wattage at the higher voltage will be less.
I think your confusion is thinking of electricity as an engine where more horsepower should yield faster car. This is more like a teeter totter. Electricity wants to balance in the same way.
448W = 12v and 37a the same as 448W = 14v and 32a. Both systems are 448Ws
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
