06 jetta diesel tach input?
todds440
Member - Posts: 48
Posted: January 12, 2008 at 8:54 AM / IP Logged
Plan on doing  R/S install on 06 Jetta diesel.  Is there a good place to grab a tach signal on this vehicle?  Also plan on using 556uw for transponder bypass.  Is method 2 on the directions,  what most of you guys are using for VW's(splice into factory transponder ring circuit)?  Any input is appreciated.  Thanks
tedmond
Gold - Posts: 4,610
Posted: January 12, 2008 at 11:24 AM / IP Logged
06 jetta diesel tach input? -- posted image.Tachometer RED / WHITE (-) AT INJECTOR #1
ALSO AT ECM MODULE AT CENTER OF FIREWALL
i would leave the rind alone and not tap into the immobilizer.
todds440
Member - Posts: 48
Posted: January 13, 2008 at 6:54 AM / IP Logged
So what your saying is not to cut into wiring, do the looped wire around the cylinder?
tedmond
Gold - Posts: 4,610
Posted: January 13, 2008 at 9:18 AM / IP Logged
correct, use the RF ring they gave to you. This is because you are unsure which are your data wires.
