compustar engine sensing yellow/bk wire
dman702
Member - Posts: 8
Posted: January 31, 2008 at 10:30 PM / IP Logged
My car is a 2005 dodge neon with a 5 speed transmission.
Can i connect the CN3 #9 Yellow/Bk engine sensing wire to the alternator? My car doesn't have a tach wire. On the manual it says learning tach/Injector wire and right under that it says Alternator sensing. Does that mean I can use a tach wire, injector wire or an alternator wire for the engine sensing?
I appreciate any help.
Thanks,
Dave
chadwa2003
Copper - Posts: 353
Posted: January 31, 2008 at 11:22 PM / IP Logged
You can use an injector no problem if you use alternator sensing you must program it to accept it
dman702
Member - Posts: 8
Posted: January 31, 2008 at 11:58 PM / IP Logged
How can I find the correct injector wire? Do I need a test light or a voltmeter?
Thank you for your help.
Dave
tedmond
Gold - Posts: 4,610
Posted: February 01, 2008 at 7:07 AM / IP Logged
voltmeter for sure. set it to AC, and test your wire by placing black to ground and red to the wire you are testing. the wire will show anything from 1v AC - 6.6v AC. it always fluctuates
usabuilt
Copper - Posts: 161
Posted: February 01, 2008 at 9:08 AM / IP Logged
The correct injector wire is the wire that is not common, the injectors will have two wires, one wire will be the same color on all the injectors and the other will be different, use the uncommon color. no meter is necessary.
StealthEs
Copper - Posts: 326
Posted: February 01, 2008 at 9:38 AM / IP Logged
Did you change the setting of the CN3 #9 Yellow/Bk  for engine sensing, otherwise it still set for tach. You  have to change the setting. You're better off just going to the injectors like everyone says.
Cris
StealthEs
Copper - Posts: 326
Posted: February 01, 2008 at 10:03 AM / IP Logged
If you still rather do Alternator sensing you have to change Option group 2,   2-10 to option 2.
Cris
usabuilt
Copper - Posts: 161
Posted: February 01, 2008 at 10:06 AM / IP Logged
why do you say your car has no tach wire?? There is no coil on the top of the engine??/ injector wires are not as good as a tach.
dman702
Member - Posts: 8
No, I didn't change the setting of CN3 #9 Yellow/Bk for engine sensing.
How do I change the setting to make it work with the injector wire?
BTW can I connect a tachometer with a shift light on an injector wire?
Thank you everyone that has reply.
StealthEs
Copper - Posts: 326
Posted: February 01, 2008 at 10:12 AM / IP Logged
I dont see why you couldn't. I would just connect each to their own injector though. As far as to change the options, I have a programmer so I'm not sure how you would go about doing it without it. Just go to the injector.
Once conncted start the car with the key, step on the brake, activate the remote start from the control your lights should blink to confirm that a good tach has been learned.
Cris
