2000 galant factory alarm and immobilizer
TJ92Civic
Copper - Posts: 161
Posted: March 06, 2008 at 3:57 PM / IP Logged
Hey I found this diagram on here and just have two questions...
|              12V|blue / YELLOW         |+  |ignition harness            |
|          STARTER|BLACK / YELLOW        |+  |ignition harness            |
|         IGNITION|BLACK/ white         |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
| SECOND ACCESSORY|blue/black          |+  |ignition harness            |
|       POWER LOCK|purple              |-  |either kick panel or *1     |
|     POWER UNLOCK|lt. GREEN/ red       |-  |either kick panel or *1     |
|       LOCK MOTOR|blue/red            |   |drivers kick panel          |
|     UNLOCK MOTOR|blue/black          |   |drivers kick panel          |
|    DISARM DEFEAT|blue/orange         |   |passenger kick panel        |
| PARKING LIGHTS +|GREEN / WHITE         |   |at the fuse box             |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|GREEN/ orange        |-  |top front of the fuse box   |
| DOME SUPERVISION|                    |   |                            |
|  TRUNK/HATCH PIN|white               |-  |at light in the trunk       |
|         HOOD PIN|blue/black          |-  |underdash fuse box          |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|red *4              |-  |drivers door harness        |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|white               |   |instrument cluster or *2    |
|      SPEED SENSE|yellow/black        |   |instrument cluster or radio |
|       BRAKE WIRE|green               |+  |brake pedal switch          |
|     HORN TRIGGER|GREEN / WHITE         |+  |*3                          |
|           WIPERS|blu/red, blu/org    |+  |wiper motor                 |
|  LF WINDOW UP/DN|RED / blk - grn/blk   |A  |drivers door switch         |
|  RF WINDOW UP/DN|RED / wht - grn/wht   |A  |drivers kick panel          |
|  LR WINDOW UP/DN|green - yellow      |A  |drivers kick panel          |
|  RR WINDOW UP/DN|orange - grn/yel    |A  |drivers kick panel          |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start.  *1 The door lock wires are in a black plug behind the fuse box, above a green module.  *2 On the 6 cylinder models, the white tach wire can also be found at the distributor. On the 4 cylinder models, the tach wire can also be found at the ignition failure sensor on the intake manifold, the white wire is in a 4 pin plug with three BLACK/ stripe wires.  *3 Horn relay in engine compartment relay box, or also found right at horn behind left side of front bumper.  *4 When doing remote start on vehicles with factory alarm, must also interrupt the blue/red (-) key sense wire at the steering column using the status output wire to bypass the factory starter kill.
1.) For the factory alarm disarm states "When doing remote start on vehicles with factory alarm, must also interrupt the blue/red (-) key sense wire at the steering column using the status output wire to bypass the factory starter kill."
Does this mean there is no alarm disarm wire, you just need to hook the status wire up to the key sense wire? So the car thinks the key is in it and bypasses the starter kill? Or is there a relay needed?
2.) Some models have an immobilizer system that needs to be bypassed during remote start.
Anyone know what models have the immobilizer? Or what the key will look like? And 556u will work if needed?
Thanks.
KarTuneMan
Platinum - Posts: 7,056
Posted: March 06, 2008 at 9:56 PM / IP Logged
look for a yrellow/white to disarm, in the drivers kick. It will pulse negative when turning the key in the door.
Yellow is for arming, same location, same polarity.
TJ92Civic
Copper - Posts: 161
Posted: March 06, 2008 at 10:29 PM / IP Logged
Ok thanks. Will i still need to use the key sense wire to bypass the starter kill?
tedmond
Gold - Posts: 4,610
Posted: March 07, 2008 at 2:10 PM / IP Logged
usually using key sense just allows the car to disarm since it sees a "key" in the ignition. you arent using the key sense wire to bypass the starter defeat(immobilizer) you use the status output or ground out when running to trigger a bypass unit.
lavie2k9
Posted: April 11, 2008 at 9:42 AM / IP Logged
How would I hook up the yellow wire to arm my factory alarm when I lock my car?
I have a remote start module, but I don't know if it has the wire to hook up to the factory alarm.
I have the Autocommand OEM 28624TN
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
