prostart 3400 blows its computer
comet291
Member - Posts: 7
Posted: April 20, 2008 at 6:57 AM / IP Logged
hi i have the Canadian Tire Pro Start 3400  but now the computer is blown i guess if i unlock doors  the trunk pops  if i lock doors trunk pops  remote start doesnt work anymore it pops the trunk and unlocks the doors
i put 400v diodes on the remote starter wires to the replays of the trunk lock and unlock so voltage doesnt go back into the computer  but that didnt work.  are there other wires i need to put the diode on? and i read about quenching diodes  but is that a diode thats built into the relay? or how does that work or what do i need to do  since it talks about taking the voltage  or what not is there any pics or anyone have details on what i did wrong or didnt do
comet291
Member - Posts: 7
Posted: April 20, 2008 at 7:37 AM / IP Logged
hi i read the topic "whats ther reason to diode isolate"  now i have a question  since they showing images and saying its reversed
since the remote starter is a trigger (-)   does the diode go cathodide side (stripped) side to the trigger  and the anode side(no stripe)  to the 12 volt side or is it the other way around?
Platinum - Posts: 13,726
Posted: April 20, 2008 at 8:12 AM / IP Logged
comet291
Member - Posts: 7
Posted: April 20, 2008 at 9:22 AM / IP Logged
so i still not 100% sure since it talks about being reversed   which one do i choose
is it the
2nd option  12v  to the anode side and the trigger to the cathode side since that be the reverse order i guess of the prostart?  is that how id do it?
Platinum - Posts: 12,488
Posted: April 20, 2008 at 9:26 AM / IP Logged
Bring it back to Canadian Tire. They will accept returns on almost anything.
comet291
Member - Posts: 7
Posted: April 21, 2008 at 9:53 AM / IP Logged
ok ill try that return
but  still like to know  which way em i to solder the diode in place from connector 85 and 86  since it is a (-) negative trigger from the remote car starter
mrcllusb
Copper - Posts: 489
Posted: April 21, 2008 at 10:34 AM / IP Logged
Look at it this way.When you have a (-) trigger output from your alarm,you want your diode stripe away from your brain,because your alarm once armed,is looking for just a triggered input signal from that trigger ie. a pin switch.That explains the third diode down example.
"ole blake"
comet291
Member - Posts: 7
Posted: April 22, 2008 at 7:04 AM / IP Logged
ok so the brain is the car alarm  i take it  so then id use the 2nd option  since the stripe goes the opposite direction for positive  so that way it wont send power to the (-) trigger then right
so i put the non stripped end on the trigger wire and the stripped size  to the 12 volt relay 85 side correct?
mrcllusb
Copper - Posts: 489
Posted: April 22, 2008 at 10:03 AM / IP Logged
If your vehicle requires diodes,you would place them on the wires from your relays that go to your lock/unlock and trunk release wires in your vehicle with the stripe side away from your alarm if your lock/unlock and trunk pop are (-) trigger.The wire from your alarm to the relay doesn't need a diode if i'm correct.
"ole blake"
comet291
Member - Posts: 7
Posted: April 22, 2008 at 2:10 PM / IP Logged
ah well my car is (+)  polarity  and the remote starter is (-) polarity  so i have to use  a relay
so then for my situation ill solder a the diode from the trigger wire from the remote starter   bare side and the relay side of 85  gets the stripe side correct?
