lock/ unlock wire color 07 infiniti g35
infiniti2007
Copper - Posts: 67
Posted: August 18, 2008 at 9:05 AM / IP Logged
Hi, could someone tells me, what is the colors wires for lock/unlock for 2007 infiniti g35x ( sedan)?, and exactly where they located? Thanks
hhh
Platinum - Posts: 13,726
Posted: August 18, 2008 at 10:17 AM / IP Logged
lock/ unlock wire color 07 infiniti g35 -- posted image.Power Unlock BLUE/WHITE (-) AT SWITCH IN DRIVERS DOOR
lock/ unlock wire color 07 infiniti g35 -- posted image.PowerLock RED / WHITE (-) AT SWITCH IN DRIVERS DOOR
infiniti2007
Copper - Posts: 67
Posted: August 18, 2008 at 2:59 PM / IP Logged
Are they inside the door panel?. Do I have to remove the door panel and run the wires from door to driver side kick?.  Thanks .
hhh
Chris Luongo
Platinum - Posts: 3,746
Posted: August 18, 2008 at 3:11 PM / IP Logged
www.idatalink.com
Select what kind of car you have, and there are two different products you could use to do a remote start on that car.
On either product, click "Guides." The guide will show you the two empty pins at the BCM where you can add wires for lock and unlock.
infiniti2007
Copper - Posts: 67
Posted: August 18, 2008 at 3:17 PM / IP Logged
Yes, I already have hooked up like that, but it does not works when you armed ( Locked)  and let it sit for half hour or so, then if you disarmed ( unlocked) it only disarmed the vehicle but does not unlock the door.
hhh
Posted: August 18, 2008 at 3:21 PM / IP Logged
I would have to assume that you need to run wires into the door.  If they were available in the kick panel, they would have told us to look there.
moonliter
Copper - Posts: 322
Posted: August 18, 2008 at 4:10 PM / IP Logged
Would it work if you set it up as double pulse unlock ?
Posted: August 18, 2008 at 4:30 PM / IP Logged
I can only imagine that you are trying to use the factory keyless to trigger a remote start.  I am not sure about the Nissan/Infiniti system, but on a Toyota, when the vehicle is running, the keyless no longer works.  So yes unlock unlock should start the vehicle.  Only problem with that is you may not be able to lock the doors back while the vehicle is running.
To check, start the car and try to lock or unlock the doors with the keyfob.
infiniti2007
Copper - Posts: 67
Posted: August 18, 2008 at 8:18 PM / IP Logged
I got everythings worked perfectly, even to start the vehicle with the remote starter, lock and unlock worked great. The thing is, right now is summer time. If you armed the vehicle, it will armed and locked the vehicle, after while you came back , you try to disarmed the car , it will disarmed the car without unlocked the doors. But if you use the remote starter to starts the car, then lock and unlock will work normally. It only DOES NOT work if you armed the vehicle and after awhile you disarmed the vehicle WITHOUT use remote starter, It will not unlock the doors.
hhh
KPierson
Platinum - Posts: 3,527
Posted: August 18, 2008 at 8:57 PM / IP Logged
You can five wire the door lock actuators at the BCM.  This would be a band aide to cover up some sort of problem, but it would work.
Kevin Pierson
Page of 4
