12 volt wire loses voltage
charger1970
Posted: September 06, 2008 at 8:39 PM / IP Logged
I am installing an anti theft device in a 2008 charger.  Everything is fine except one thing.  The wire I am using as my trigger voltage shows 12 volts all of the time when the key is on.  The problem is when I touch the input wire from my product to the 12 volt output, the voltage drops down to 0 volts.  When I remove the wire it pops back up to 12 volts.  Several 12 volt wires on this car do the same thing.  Is there anything I can put in between the 2 wires to prevent this voltage from dropping out?
Thanks in advance !
Posted: September 07, 2008 at 4:24 AM / IP Logged
Suggest using fusebox output.
charger1970
Posted: September 07, 2008 at 3:54 PM / IP Logged
Thanks for the reply.  The problem is I need a 12V signal when the key is on and in run and 0V when the key is off.  I tried the Ign 1 circuit and it messes up the computer even with a diode.  I have found three others that do the trick but they lose voltage as soon as you touch my products input wire to it.  Then when I remove my input wire it reads 12V again.  Thanks in advance for your help.
enice
Silver - Posts: 857
Posted: September 07, 2008 at 4:29 PM / IP Logged
there may be something wrong with the actual product.
megaman
Copper - Posts: 385
Posted: September 07, 2008 at 4:36 PM / IP Logged
sounds like your 12v input to your product is ground.  Whenever you touch it to 12v, it goes to ground.  Either it's the wrong wire, or there's something wrong with your product.
Platinum - Posts: 13,723
Posted: September 07, 2008 at 4:41 PM / IP Logged
You need to use a transistor.  I will have some time tonight to draw you a diagram.  There is not enough current capacity on that wire that you are using.  You will have to use it to turn on the transistor.  You can get about 2 amps of current using the transistor only, if you need more current you will have to use the transistor to power a relay.
Posted: September 07, 2008 at 4:48 PM / IP Logged
12 volt wire loses voltage -- posted image.
Posted: September 07, 2008 at 5:45 PM / IP Logged
Thanks enice I was thinking that way, are you trying to connect an ign sense or the ign in break. If it's the former you definately have a short to ground sence the ign. sese wire on an immobiliser at most has to trip a relay or (2 x relay) coil. Craig, nice to see you floating back! sorryh every pun intended.
0
Posted: September 07, 2008 at 6:05 PM / IP Logged
Floating for now.    This was by far the worse one I have been through.
charger1970
Posted: September 07, 2008 at 7:31 PM / IP Logged
Thank you guys !  I am using the wire to sense when the ignition key is on.  And as I stated when I touch my input Sense wire to the 12V output wire I chose,  the voltage drops to 0V.  I will try the transistor.  I will have to use a relay with it however because I think the circuit will draw between 3-15 amps.  Thanks again !
Mike
Thursday, November 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
