08 chevy silverado diesel
p01110101
Member - Posts: 43
Posted: November 21, 2008 at 5:48 PM / IP Logged
I am using an ADS-AL-CA with and autopage rs-900 lcd and cannot seem to get the tach signal over rs232 or thru the tach output wire on the ADS-AL-CA. any ideas, also having trouble with starter wire and i can't seem to find the glow plug wire. but aside from all that everything else works.
Mike M2
Platinum - Posts: 2,652
Posted: November 21, 2008 at 7:02 PM / IP Logged
If you are connecting the two together thru the DBI link that is your problem. I have done dozens of them and the tach signal never seems to work on GM products. To cure this, i hard wire the RS to the Idatalink and it works every time....
Mike M2
Tech Manager
CS Dealer Services
p01110101
Member - Posts: 43
Posted: November 22, 2008 at 4:34 PM / IP Logged
thanks, any ideas for the starter/glowplug i have a 1300ohm resister on the stater wire and i can't seem to get it to work/ any ideas where there might be a glow plug wire?
ckeeler
Gold - Posts: 1,461
Posted: November 22, 2008 at 8:06 PM / IP Logged
you CANNOT use the glow plug wire on this vehicle even if you were able to find it. it  is done through data. if you must use it rather than through the module programing, use a DEI 528T for the wait to start.
p01110101
Member - Posts: 43
Posted: November 23, 2008 at 1:10 AM / IP Logged
i don't need a 528t the autopage has a built in delay. any ideas for starter?
Mike M2
Posted: November 23, 2008 at 6:30 PM / IP Logged
What are you asking? What issue do you have with the starter wire?
Mike M2
Tech Manager
CS Dealer Services
p01110101
Member - Posts: 43
Posted: November 23, 2008 at 7:14 PM / IP Logged
never mind i figured it out, this is our first time using autopages RS's so figures we would run into a couple of issues. thanks for the help.
Nothing last's like the temporary.
