2009 chrysler 300, relay, ignition
russbm
Member - Posts: 46
Posted: April 29, 2009 at 8:21 AM / IP Logged
Need help for wiring a relay to a thin ignition 12v Pink/white wire for seat heater that will turn on with the key on and turn off with key off.
KarTuneMan
Platinum - Posts: 7,056
Posted: April 30, 2009 at 12:14 AM / IP Logged
Thats gonna really suck this summer.......
russbm
Member - Posts: 46
Posted: April 30, 2009 at 12:54 PM / IP Logged
I really need help on this please. Doing a 2009 Chrysler 300, putting seat heater on both front seat and need to know which wire to add a relay on the pink/white wire on the ignition switch. What will the layout be on the relay. Hope this make sense.
Posted: April 30, 2009 at 3:46 PM / IP Logged
If KTM can't Howie can, ground to switch to 85, ignition to 86, 12v+ permanent via a 30amp fuse to 30 and 87 to the seat heaters. Place a 1N4004 diode across 85 and 86 with the band towards 86, run a 12volt LED with power to one side and ground side to switch  side of 85.
