remote start won't stay running
rjnel_1
Posted: January 09, 2010 at 8:03 PM / IP Logged
I am installing a bulldog security rs1200 with a 791 bypass in a 2005 Chevy Silverado all the wiring appears to be correct but the vehicle starts with the remote runs for about 5 seconds then shuts off then restarts runs for 5 more seconds and repeats does anyone have any suggestions as to what the problem could be ?
Platinum - Posts: 13,725
Posted: January 09, 2010 at 8:49 PM / IP Logged
What wire did you tag for tachometer?
rjnel_1
Posted: January 09, 2010 at 9:10 PM / IP Logged
I was trying to do it tach less but tomorrow I'm going to wire the tach in.
Posted: January 09, 2010 at 9:31 PM / IP Logged
That will fix it.
rjnel_1
Posted: January 10, 2010 at 10:18 AM / IP Logged
Is there any way to connect to the tach wire without digging into the pcm it looks like a great place to screw up and end up with a totally disabled vehicle. The directions refer to the white wire in the green plug but all 4 plugs look black ??
Platinum - Posts: 7,828
Posted: January 10, 2010 at 2:50 PM / IP Logged
You could try a Fuel Injector.  Each one has 2 wires.  One is a common wire that is at all injectors.  The other is a unique color for each Injector.  I have found that Bulldog units prefer a strong signal and sometimes won't learn the Injector of coil signal.
The best place for the Bulldog is:
PCM Located On The Drivers Side Of The Motor. Tach Wire Is In The BLUE Conn (C1)
Closest To The Firewall,Pin #49 or also found back of Instrument Cluster, White wire in 24 pin GRAY Conn Pin # A12.
misterjimbo
Silver - Posts: 535
Posted: January 12, 2010 at 3:48 PM / IP Logged
if it is the old body style there is a white at the cluster. only one plug and only one white wire
Friday, March 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
