remote starter 2003 town & country
cascobay
Member - Posts: 11
Posted: December 11, 2010 at 3:35 PM / IP Logged
I just installed an Avital 4113L into my wife's 2003 Town and Country minivan.
The remote start works, but it will crank for 3-6 seconds and stop, it will then attempt to restart and it will fire up and run without any issues. I did install the 180 ohm relay via relay on the correct wire within the ignition harness, without this it did not work.
I have the tach wire hooked up to the ignition coil, I had the remote start unit learn the tach signal as well. Everything seems fine there.
The unit works but I am just wondering why it always takes 2 attempts to start, it is cranking over with plenty of duration so that is not the issue.
Any tips? I have installed 3 remote starters in the past without any issue. I am also a licensed master electrician, so I have the basic skill set but I recognize the need for some guidence here.
The other issue I have is no climate control power when remote started, I suppose I need a relay to supply power to the climate control circuit?
Thanks for the help!
cascobay
Member - Posts: 11
Posted: December 11, 2010 at 3:38 PM / IP Logged
That should be-
"180 ohm resistor via relay"
zerepdivad
Silver - Posts: 605
Posted: December 11, 2010 at 3:42 PM / IP Logged
try tach at the pcm...
     Tachometer          DARK BLUE/GREEN          (AC)          PIN 11 AT PCM LFT CORNER OF ENGINE COMP.
A DMM is a beautiful thing.
cascobay
Member - Posts: 11
Posted: December 11, 2010 at 3:45 PM / IP Logged
Thanks for the quick reply.
Maybe I am wrong, and please correct me if I am, but the tach signal is a reference for the remote starter so it can figure out how long to crank the engine over, right?
My enging cranking duration is fine, it cranks 3-4 times longer than it normally takes to start wih a key.
zerepdivad
Silver - Posts: 605
Posted: December 11, 2010 at 3:49 PM / IP Logged
yeah.
Put the key in and turn it to the run position and try the remote starter and see if it does the same thing. I notice it only lists one ignition wire but did you by chance have any wires in the ignition harness left over?
cascobay
Member - Posts: 11
Posted: December 11, 2010 at 3:51 PM / IP Logged
It does the same thing with the key in the run pos.  I do not have any extra wires at the ignition harness.
zerepdivad
Silver - Posts: 605
Posted: December 11, 2010 at 3:53 PM / IP Logged
this will sound weird but try programming the wait to start for a few seconds. it's possible the fuel is not getting up there quick enough if that makes sense. i've had to do that in the past.
cascobay
Member - Posts: 11
Posted: December 11, 2010 at 3:56 PM / IP Logged
I can try that but the fuel pump runs and shuts off before the starter is engaged- the delay is pretty long as is.
zerepdivad
Silver - Posts: 605
Posted: December 11, 2010 at 3:59 PM / IP Logged
hmm well usually if tach is learned properly it will keep on cranking until it starts up. did this van even have an immobilizer?
cascobay
Member - Posts: 11
Posted: December 11, 2010 at 4:06 PM / IP Logged
It does not have an immobilzer.
I think the remote starter is cranking he default of 6 seconds and gives up, and trys again. It is just odd because the second attempt ALWAYS works without delay.
Thanks for all your help.
