remote start 2000 escalade
sk8tordeye
Posted: February 03, 2011 at 10:57 AM / IP Logged
Can someone tell if the pink ignition that i need to tap into for remote starting is the larger or smaller wire? i have two in my harness both get 12v's with the turning of my key.
Twelvoltz
Platinum - Posts: 2,384
Posted: February 03, 2011 at 3:08 PM / IP Logged
It's the larger wire. The one that follows the other ignition harness wires all the way up to the key cylinder.
sk8tordeye
Posted: February 03, 2011 at 3:21 PM / IP Logged
thank you for the info. now that will be the same with my white wire also.
KarTuneMan
Platinum - Posts: 7,056
Posted: February 03, 2011 at 10:39 PM / IP Logged
Sounds to me like you might NOT be testing the wires before you make your connection......
sk8tordeye
Posted: February 03, 2011 at 11:58 PM / IP Logged
No I test and retest that's why I question, same color same volts different ga. of wire.
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
