2006 chevy express remote start shut down
Member - Posts: 18
Posted: January 16, 2012 at 11:25 PM / IP Logged
Does anyone know how the security system in a 2006 Chevy Express works and how to bypass it. Every time the Van is remote started a security light comes on where the gauges are and then the engine shuts off. The owner says that there is no Chiip in his key as he has made copies at Home Depot and he proved that. I don't know if there is some kind of key sense wire or something but any ideas would be greatly appreciated. Thank you
prdjr165
Copper - Posts: 293
Posted: January 17, 2012 at 4:25 AM / IP Logged
This vehicle uses GM'S PASSLOCK 2 ANTI-THEFT SYSTEM that requires a 791 Bypass
Module to Remote Start,
Platinum - Posts: 7,828
Posted: January 17, 2012 at 5:21 AM / IP Logged
Bypass for the Passlock2 system in your van :
http://documents.audiovox.com/700054.pdf
Member - Posts: 18
Posted: January 17, 2012 at 3:32 PM / IP Logged
Does all of those Vans have the GM Passlock2?
Posted: January 17, 2012 at 4:07 PM / IP Logged
Sure sounds like yours does.  There is no transponder chip in the key.  The Passlock2 system
is resistor based and in the ignition key cylinder.  Open up the steering column and look for
a group of 3 thin gauge wires coming from the ignition cylinder.  They will be either White,
Black and Yellow or RED / White, ORANGE / Black and Yellow.
Example below :
2006 chevy express remote start shut down -- posted image.
Member - Posts: 18
Posted: January 18, 2012 at 8:37 PM / IP Logged
Does anyone know what would be the most cost effective bypass to use in this case. Since everything else is hooked up and and working the owner is not looking to spend more than $30 on the bypass if possible.
Posted: January 18, 2012 at 9:32 PM / IP Logged
The cheapest way is with the relays and resistor - about $10.
Next is a DEI 555L, 555LW or 556LW  bypass module.  They are no longer in production but are available at "online" sites for under $25.  Just make sure it is "new in the box" with all harnesses.  Easy to install, program and reliable.
Here is a link for the install guide  :   http://www.xpresskit.com/product.aspx?productid=41
Member - Posts: 18
Posted: January 19, 2012 at 11:43 AM / IP Logged
Thanks Kreg I appreciate it man!
zerepdivad
Silver - Posts: 605
Posted: January 20, 2012 at 7:54 PM / IP Logged
You didn't know the vehicle had passlock and you're installing remote starts for others?
A DMM is a beautiful thing.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
