dei 555l
rawcustumz
Member - Posts: 46
Posted: February 15, 2012 at 4:49 PM / IP Logged
will the DEI 555L work with a 2002 Buick Rendezvous cx, I checked the manual and it doesnt list it but list trucks, suvs and vans 1998 - 2002 any help would be great
Bernie
Bernie
MECP Certified
64 Impala Wagon
2007 Camry LE
tedmond
Gold - Posts: 4,610
Posted: February 15, 2012 at 5:42 PM / IP Logged
im sure this vehicle is passkey 3, and not passlock. if it is passkey, the 555l will not work.
Ted
Compustar Expert
Twelvoltz
Platinum - Posts: 2,384
Posted: February 15, 2012 at 6:09 PM / IP Logged
In that era of DEI bypasses the 555GW would work with the 02 Rendezvous. There are several on ebay, I still have a couple on the shelf. There are also a bunch of current models offered. The Idata ADS-TB would do transponder bypass, or you could use the ADS-AL CA which would do bypass and door locks through data too. Both of the ADS pieces would require flashing before installing. Fortin offers the EVO-ALL which would do door locks, bypass, and even parking lights and comes pre-flashed.
rawcustumz
Member - Posts: 46
Posted: February 16, 2012 at 7:39 PM / IP Logged
Ok thanks for the info im just gonna use the FLCAN and flash it.
Bernie
Bernie
MECP Certified
64 Impala Wagon
2007 Camry LE
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
