2004 Chevy Colorado Security Bypass
jaxzin
Copper - Posts: 87
Posted: December 22, 2012 at 10:38 AM / IP Logged
Hi all,
A lot of you guys may know all about the Colorado and GM's Passlock II system. Basically the cars computer reads a resistance signal from the key cylinder in order to let the fuel injectors turn on. I have a 2004 Colorado with 46K miles. I've posted here before about help with battery issues and aftermarket alarm issues and have gotten the help I needed.
I am again asking for assistance. My truck is having problems with the Passlock system and to get it fixed the right way at the dealership it is right at about $700 which I can't afford at this time. The symptoms it has is the dreaded crank and no start with the Anti-Theft system light blinking on the dash. You wait 10 mins and it starts up with no problem. I have a 4 month old son now and I would hate to be in a position of an emergency and this issue happen.
There is a way to bypass the passlock system for those using a remote start alarm like so.
Colorado remote start bypass
What I am needing help with is figuring out the relays without using a remote start alarm system. I have made a preliminary document which I think is correct but I wanted some experts opinions before I tried it. I can't post it here because it would violate the rules being how it can be used by someone to possibly disable a system from a vehicle that isn't theirs but it would take a long time.
If anyone can help me out I would send you the diagram offline or privately for review. Again thanks for all your help.
pentavolvo
Copper - Posts: 241
Posted: December 22, 2012 at 11:39 AM / IP Logged
to permanently bypass just get resistor of correct value
cut white and blue wire and put resistor from ecm side to WHITE/ yellow wire
tape off the key side of WHITE/ blue wire
done
Platinum - Posts: 7,828
Posted: December 22, 2012 at 11:46 AM / IP Logged
As above, here is a link to a prior post on the Passlock2 immobilizer system.
https://www.the12volt.com/installbay/forum_posts.asp?tid=123309&KW=racing%5Fbidule
Of particular interest is the input from "racing_bidule".  For additional security, you could include a hidden toggle switch with the resistor wire link.  that would allow you to disable the Passlock2 bypass when necessary.
jaxzin
Copper - Posts: 87
Posted: December 22, 2012 at 2:38 PM / IP Logged
Thanks for the input guys. Being how this has already been posted before and some diagrams are already up I can post mine and I think it does not violate the forums rules.
Basically it's the same thing but with the addition of the second relay it allows the system to go back to stock configuration even though the wires are cut. Problem with leaving the key side just cut and taped is that you will have the security light flashing on the dash the whole time.
Here is what I modified from AudioVox. Basically its the same system but it omits the remote start / alarm system and just bypasses Passlock all together.
2004 Chevy Colorado Security Bypass -- posted image.
ziggyb222
Silver - Posts: 593
Posted: December 22, 2012 at 3:21 PM / IP Logged
I would make sure it is not the ignition switch itself.... there have been many problems with these switches... just did an install the other day and it was about the sixth one I was told the switch was replaced..... just a thought????
jaxzin
Copper - Posts: 87
Posted: December 22, 2012 at 3:38 PM / IP Logged
Sure. I can check that. maybe just replace it all together since its cheap.
pentavolvo
Copper - Posts: 241
Posted: December 22, 2012 at 4:22 PM / IP Logged
just doing resistor without a relay should not flash security light
beegbie
Copper - Posts: 341
Posted: December 22, 2012 at 5:53 PM / IP Logged
I don't think this is possible without a second switch. The resistor (passlock) value is only sent during crank. Your diagram has it feeding that value the whole time. It may work but your not duplicating what the ignition switch is/should be doing. In my opinion, wiring up a momentary switch to replace the +start signal from a remote start would be best. Use the diagram you have but use the momentary switch to trigger +12 volts to pin 86 of the relay on the left.
jaxzin
Copper - Posts: 87
Posted: December 22, 2012 at 11:13 PM / IP Logged
Thanks for looking at the diagram. Would this way work?
beegbie
Copper - Posts: 341
Posted: December 23, 2012 at 6:41 AM / IP Logged
Nope. Same issue as above (it's actually the opposite of what we need). But you may be on to something. What we need here is for the relay on the left to only activate during crank. So if you keep pin 86 to accessory and move pin 85 to ignition, it may work. Assuming the accessory wire rests at enough ground to activate the relay.
