clifford 590.2
adrianotech
Copper - Posts: 53
Posted: February 01, 2013 at 8:09 PM / IP Logged
ANYONE KNOW HOW TO CONNECT  H3 HARNESS OF CLIFFORD 590.2  ON HONDA ELEMENT 2003
adriantech
Posted: February 02, 2013 at 1:00 AM / IP Logged
Define your question
Where to connect it?
What colours?
How to test?
How to solder the joints?
This is all a bit vague.
Posted: February 02, 2013 at 2:12 AM / IP Logged
Here's one method:- honda_element.bmp
or this version:- 611_honda_element.bmp
Either will work, note most readily available relay is a 5 pin 87a, you can use that, just don't use terminal 87a.
smokeman1
Platinum - Posts: 1,589
Posted: February 02, 2013 at 7:51 AM / IP Logged
H3/2, 6, 9, and H1/2 to White 12 volt constant....H3/4 to car side of cut BLACK/ White starter wire, H3/5 to switch side of cut BLACK/ White.... H3/1 to BLACK / YELLOW...H3/3 to BLACK/ Red...
H3/7 to WHITE/ Red,( H3/7 need to be set as ACC2 in the brain of the clifford unit, Default is Ignition 2. Can be changed in Menu 3, Item 8, Option 2)
Test and verify the wires with a Digital Multi Meter BEFORE making your connections.  Solder and tape connections. Do Not use T-Taps or scotch locks connectors.
adrianotech
Copper - Posts: 53
Posted: February 02, 2013 at 9:19 AM / IP Logged
thanks guys..
adriantech
adrianotech
Copper - Posts: 53
Posted: February 02, 2013 at 9:44 AM / IP Logged
i got it , thanks
adriantech
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
