problem with remote start on 08 f150
I'm attempting to wire the following system and I'm running into 3 problems. 1. The truck won't remote start when activated, 2 the doors won't set the alarm off when doors are opened in armed status, and 3 the parking lights won't flash when arming
2008 Ford F150 FX4 (4 Door)
Code Alarm 6551
Flashlogic FLCAN
Wires I'm using: on Code Alarm 6551
4 Pin Main Harness
1. WHITE/ Red - Parking Light Input Ground
2. White Parking Light Output Brown wire at headlight switch
3. Black Ground Ground at kick panel
4. Brown Siren Input Connected to siren through firewall
6 Pin Start Harness
1. Purple Starter Output Motor side RED / Lt Blue
2. Red Battery 12V - Lt GREEN/ Violet
3. Orange Accessory 1 BLACK/ Lt Green
4. Pink White Ignition 2 Not Used
5. Red Battery 12V - Lt GREEN/ Violet
6. Pink Ignition 1 Dk Blue/Lt Green
6 Pin Output Harness:
1. BROWN / Black Horn Output Dk Blue at steering harness
2. Blue/Black Ignition 3 Not Used
3. Violet/Black Aux 1 Not Used
4. RED / White Truck release Not Used
5. Lt GREEN/ Black Factory Disarm/Pulse before start Not Used
6. Orange Ground when armed output Not Used
8 Pin Input Harness:
1. Blue/White Instant door trigger input - Not Used
2. Green Door trigger (-) - Not Used
3. Purple Door trigger (=) Not used
4. White Blue External start input (-) Not Used
5. Gray Hood Pin Gray wire under hood (installed myself)
6. BLACK/ White Neutral Safety Ground at kick panel
7. BROWN / Red Brake input Lt Green wire at brake pedal
8. PURPLE / White Tach input Injector (not GREEN/ red)
4 Pin Alternate Output Harness:
1. Lt GREEN/ Black Factory Disarm/Pulse before start Not used
2. Lt Blue Pulse after start Not used
3. GREEN / WHITE Factory arm/Pulse after shutdown Not used
4. Black Yellow Pulse after crank Not used
3 Pin Lock output harness:
1. Blue Unlock Pink / YELLOW
2. Open
3. Green Lock Pink/Green
Here is one correction that will fix your Parking Light problem.
1. Parking Light Input should go to +12V thru a fuse. The F150Brown Parking Light wire at the Headlight switch is (+).The FLCAN must be flashed with the TB-FM2 firmware. I am
assuming you are going D2D between the FLCAN and the CA6551.The FLCAN's Pink Ignition input wire should connect to the CA6551'sPink IGN1 wire, which is already connected to the F150's Dark Blue/Light Green Ignition wire. You must set the FLCAN toData Mode ( one blink ) and then program to the truck. This willrequire two, working, non-clone keys.Can't help too much with the CA6551, not my usual brand.
Soldering is fun!FLCAN only deals with immobilizer in this truck. How do you expect it to trigger the alarm if you don't have any door triggers connected???
Also, you need to be more specific than "the truck won't start". What exectly does it do? does it crank? do the dash lights light up? Does the security light flash or go out?
Mike M2 Tech Manager CS Dealer ServicesSorry, you can NOT post a reply.
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
