viper 7504 tarp trigger
hillbille2
Posted: April 19, 2013 at 12:54 AM / IP Logged
Hello,I have a F250 2001 and installed a viper 7504 alarm. What i need is for a trigger set up so when the tarp cover is removed at any rear corner the alarm will trigger, I have tried using the trunk -trigger and a couple of reed switches and magnets glued to tarp, but it wont trigger if both are not done as one is still earthed and one not. I tried diodes to isolate them with no affect. Any ideas, Sorry about spelling I'm an Aussy.
Hillbilly
91stt
Silver - Posts: 564
Posted: April 19, 2013 at 11:08 AM / IP Logged
How are you wiring the reed switches? I don't have a manual for the 7504 but what input are you using for trigger?
This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
Posted: April 19, 2013 at 11:23 AM / IP Logged
Check your wiring, diode separated with the band to the switch, wire to the blue wire at H2/19 either grounding should trigger the alarm.
tonanzith
Gold - Posts: 603
Posted: April 19, 2013 at 12:18 PM / IP Logged
N.c. Mag/reed switches will work for this. It sounds like your using n.o. Mag/reed switches.
Gary Sather
hillbille2
Posted: April 19, 2013 at 8:13 PM / IP Logged
Hello, I have n/o reed switches wired to ground and using the trunk pin H2/19 as a trigger.The diodes used were in5404 and tried both ways.I have a bit writer and have changed to n/o and n/c to test
Hillbilly
