viper 5904 will not remote start.
triplejjj
Member - Posts: 19
Posted: May 31, 2014 at 5:09 PM / IP Logged
5904 won't remote start, but it seems like it goes thru the motions, unlock doors, instrument lights on, remote says- remote start activated. My key starts it. Any ideas?
Posted: May 31, 2014 at 5:21 PM / IP Logged
When you say your key starts it, does leaving the key in the ignition switch make it work?
triplejjj
Member - Posts: 19
Posted: May 31, 2014 at 6:11 PM / IP Logged
Sorry, to clarify I meant starting it with the key. I just tries leaving the key in the ignition
and remote starting it and I can hear it lock the doors but does not start it.
triplejjj
Member - Posts: 19
Posted: May 31, 2014 at 6:12 PM / IP Logged
tried, spell check got me.
Posted: May 31, 2014 at 6:16 PM / IP Logged
Have you got the fold out pages i.e. brief reference guide?
Look at far right, top, Remote Start Shutdown/Startup diagnostics and follow it.
triplejjj
Member - Posts: 19
Posted: May 31, 2014 at 6:23 PM / IP Logged
I'll check now.
triplejjj
Member - Posts: 19
Posted: May 31, 2014 at 6:34 PM / IP Logged
Ok I have it, Let me check it.
triplejjj
Member - Posts: 19
Posted: May 31, 2014 at 6:38 PM / IP Logged
Ok It's telling me..... Transmitter shutdown (or optional push button.
Posted: June 01, 2014 at 2:52 AM / IP Logged
Wish I knew what that meant.
Not having a joke, I've absolutely no idea what it means.
triplejjj
Member - Posts: 19
Posted: June 01, 2014 at 4:51 AM / IP Logged
Me too, The error is 4 flashes on the control panel and no flashing tail lights. The Quick reference guide does not say that the tail lights will flash on a shut down error but says
they flash on a start up error. I assume since there are no flashing tail lights and the control
panels flashes four times it is indeed a shut down problem and not a remote start problem even though it will not remote start. Sounds to me like something is telling it not to start.
Here's what the guide says (Transmitter shutdown (or optional push button). Since it says optional push button I would think that to mean trunk, door, or hood pin but it should show me an error code for those faults.
After reading some forums:
Since the remote says it's remote started and the dash lights and radio come on I have to think it's not completing the ignition circuit. I am wondering now if it's the bypass module(DBALL).
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
