installing keyless entry
dazed
Member - Posts: 22
Posted: May 22, 2003 at 6:59 AM / IP Logged
Here's the deal...my alarm has lock/unlock capabilities,but was not hooked up during original install. Anyway, Ineed to know what I need and how to's. My car has power locks (when I push the tab to lock the drivers door it also locks the pass. side, but I have to hold up on the handle for the pass. to lock). Thanks in advance.
draasch
Gold - Posts: 2,172
Posted: May 22, 2003 at 8:25 AM / IP Logged
what is the yr make and model of car?????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
jrcaraudiofreak
Posted: May 22, 2003 at 9:36 AM / IP Logged
David,
Could you tell me the wiring for a 97 Grand Am so I can do my keyless entry? Is it 3, 4, 5 positive or negative and would you be able to tell me which wire is which and color, etc.  Thanks alot!  please e-mail it too jrmcgrath2001@hotmail.com
dazed
Member - Posts: 22
Posted: May 22, 2003 at 3:20 PM / IP Logged
My car is a '93 MX6. The alarm is an older Chapman module.
dazed
Member - Posts: 22
Posted: May 22, 2003 at 3:21 PM / IP Logged
That's a mazda if you didnt know....
draasch
Gold - Posts: 2,172
Posted: May 22, 2003 at 3:24 PM / IP Logged
Power Lock ADD ACTUATOR ACTUATOR NEEDED IN DRIVER DOOR #204
Power Unlock ADD ACTUATOR ACTUATOR NEEDED IN DRIVER DOOR #204
#204- See Adding Actuator Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
dazed
Member - Posts: 22
Posted: May 22, 2003 at 3:27 PM / IP Logged
so I just need to do drivers door? do I need any relays?
dazed
Member - Posts: 22
Posted: May 22, 2003 at 3:28 PM / IP Logged
draasch
Gold - Posts: 2,172
Posted: May 22, 2003 at 3:30 PM / IP Logged
yes im not sure what your outputs are coming from the alarm.
if you add a motor and you operate the drivers door, it will control the rest of them. you can use a DLS from omega with two relays. it makes it soooo much easier
Good Luck
David
Ace Security
813-376-9778
Tampa
dazed
Member - Posts: 22
Posted: May 23, 2003 at 7:03 AM / IP Logged
two outputs from the alarm say lock and unlock, but not wiring going to them. i assume that is where i need to
wire up. what is a DLS? door lock system? Thanks for the help.
