Alarmed Truck Accessory
hilfiger8
Posted: January 05, 2016 at 6:42 PM / IP Logged Link to Post Post Reply Quote hilfiger8
Had someone ask me today if there is a way to have an alarm tripped if wiring is cut to a light bar. Is there anyone that can think of a way. Im coming up with a blank.
Thanks in advace
Ween
Platinum - Posts: 1,368
Posted: January 05, 2016 at 6:50 PM / IP Logged Link to Post Post Reply Quote Ween
directed 502T closed loop trigger module, but you'll need to add an additional wire to the light bar wiring.
hilfiger8
Posted: January 05, 2016 at 7:01 PM / IP Logged Link to Post Post Reply Quote hilfiger8
I appriciate the fast response, ive been trying to find a manual on the 502t with no luck. What would have to be added to light bar to make this work? Thanks
Ween
Posted: January 05, 2016 at 7:23 PM / IP Logged Link to Post Post Reply Quote Ween
Per instructions..."(-) ground loop input. Run this wire through the object to be protected and then connect to chassis ground." So the additional wire could connect to ground inside the light if available, or just looped into the light then back to the vehicle chassis.
Posted: January 06, 2016 at 3:38 AM / IP Logged Link to Post Post Reply Quote howie ll
Having similar problems here in the UK with M/Sprinter cats.
Use a DEI alarm with normal closed trigger inputs.
Run trunk or hood trigger with roof lights and ground it to a mounting bolt.
Set as normally closed.
