Posted: January 29, 2018 at 10:51 PM / IP Logged
Posted: January 30, 2018 at 8:08 PM / IP Logged
Posted: January 31, 2018 at 9:02 PM / IP Logged
Posted: February 01, 2018 at 6:35 AM / IP Logged
Posted: February 01, 2018 at 9:40 PM / IP Logged
Posted: February 02, 2018 at 4:48 AM / IP Logged
Posted: February 02, 2018 at 8:59 PM / IP Logged
Posted: February 14, 2018 at 9:05 PM / IP Logged
Posted: February 19, 2018 at 2:15 PM / IP Logged
Posted: February 19, 2018 at 6:14 PM / IP Logged
Saturday, December 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
The LT denotation in the LT BLUE/BLACK (-) BLACK 26 PIN PLUG stands for Light Blue with Black stripe.
Yes, the Parking Light jumper is usually taped to the top of the 4105 module. It is used to set the polarity
of the White Parking Light output wire. If you look closely at the 4105 module, molded into the black plastic
beneath the 3 pins, are marking for correct jumper orientation. As noted above :
White set to (-) BLACK/LIGHT GREEN (+) @ SJB, BLUE 52 Pin Plug, Pin 31 add * verify polarity
You would need to locate this Parking Light control wire in the car, verify the needed polarity
( found conflicting info on this wire ), set the 4105 jumper accordingly and make the connection.
Is there something wrong ..??
