2010 F250 6.4l Remote Start
Welcome Guest :)
dunn0321
Member -
Posted: June 29, 2018 at 9:48 PM / IP Logged
I have installed an avital 5305l with EVO-ALL I am using d2d but can't get the truck to remote start. It will unlock and lock but won't start. What am I missing?
Josh Dunn
cpalmer
Copper -
Posted: June 30, 2018 at 9:41 PM / IP Logged
Do the parking lights flash when you attempt to remote start?
dunn0321
Member -
Posted: June 30, 2018 at 9:42 PM / IP Logged
No they don't only when you lock and unlock it?
Josh Dunn
chev104275
Gold -
Posted: July 01, 2018 at 7:22 AM / IP Logged
Where do you have the black/white netural saftey wire connected ? Is there a valet switch ?
If i Can't Install it I Don't need it Joe
dunn0321
Member -
Posted: July 01, 2018 at 11:32 AM / IP Logged
Is it a solid white or black or is it a white and black wire
Josh Dunn
dunn0321
Member -
Posted: July 01, 2018 at 11:35 AM / IP Logged
There is not a valet switch
Josh Dunn
dunn0321
Member -
Posted: July 01, 2018 at 2:05 PM / IP Logged
Looking on the Evo all and the avital 5305l there is not a safety netural wire. I have hooked it up according to the Evo all manual
Josh Dunn
chev104275
Gold -
Posted: July 01, 2018 at 7:51 PM / IP Logged
Pin 13 of the 24 pin connector black with a white strip. Where is that wire going ?
dunn0321
Member -
Posted: July 01, 2018 at 7:59 PM / IP Logged
That one isn't going anywhere
Josh Dunn
chev104275
Gold -
Posted: July 01, 2018 at 8:37 PM / IP Logged
It needs to see ground for the remote start to work. I'm assuming your truck is an automatic. You can ground the wire through a switch or straight to ground
Wednesday, May 13, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
