2008 Honda Accord, Remote Start Problem
icerw
Member - Posts: 7
Posted: June 09, 2019 at 8:23 AM / IP Logged Link to Post Post Reply Quote icerw
Hi everyone i just installed my alarm viper 5706v with bypass dball 3 and everything working but remote start not i have remote start error in my pager when i try to start
I'm not sure about my remote start wires:
Orange to orange
3 Red (all together) to white
Pink to blue
Gren and purple to yellow( green key side purple car side)
Pink white to red
icerw
Member - Posts: 7
Posted: June 09, 2019 at 2:46 PM / IP Logged Link to Post Post Reply Quote icerw
2008 Honda Accord, Remote Start Problem -- posted image.
catback
Silver - Posts: 703
Posted: June 09, 2019 at 5:01 PM / IP Logged Link to Post Post Reply Quote catback
What shutdown error are you having? Have you programmed the tach? Is the neutral safety switch wired up?
silvercivicsir
Copper - Posts: 416
Posted: June 10, 2019 at 12:17 AM / IP Logged Link to Post Post Reply Quote silvercivicsir
did you take it out of manual mode? and also ground the blk/white neutral safety wire..
icerw
Member - Posts: 7
Posted: June 10, 2019 at 3:43 AM / IP Logged Link to Post Post Reply Quote icerw
https://youtu.be/oPUruyG3Ho8
Yes black white is wired to the ground
I had the same problem before i wired the the black white ti the ground and Violet white to the injector (not black yellow)
How to take out of manual mode?
geepherder
Platinum - Posts: 3,668
Posted: June 10, 2019 at 5:32 AM / IP Logged Link to Post Post Reply Quote geepherder
Open the door.
Turn the ignition on then off.
Press and hold the valet button until you get three chirps (LED flashes), then release.
Press and release the valet button once then press and hold.
While holding the valet button, press the unlock button on your remote.
Release the valet button and either close the door or cycle the ignition to exit programming.
icerw
Member - Posts: 7
Posted: June 11, 2019 at 5:14 PM / IP Logged Link to Post Post Reply Quote icerw
Tried but same error any idea?
geepherder
Posted: June 11, 2019 at 7:09 PM / IP Logged Link to Post Post Reply Quote geepherder
When you pressed unlock during this process, did you get two confirmation chirps (or two LED flashes)? If not, try again.
Do you have a local Viper dealer nearby? If so, see if they have a Bitwriter, or XKLoader and try programming that way.
Out of curiosity, can you enable MTS mode?
aguilarpro
Member - Posts: 45
Posted: June 18, 2019 at 10:05 PM / IP Logged Link to Post Post Reply Quote aguilarpro
I had this issue as well at some point, please reference to my thread here with the same remote started and car: https://www.the12volt.com/installbay/forum_posts.asp?tid=139588
Tach info for injector is not needed for remote start for this car. If I were to guess this is the easiest install if using D2D (Data to Data), also ensure that the bypass has been flashed to your car's model and hard-wire it to the CAN data lines under the steering wheel. I had issues initially because of programming functions. I got unresponsive remote signal at some point where the accessory would work as if the car started and the remote would think the car is started and what I found out is that unplugging and replugging the bypass module would fix it. I have no explanation but it has happened twice at maybe 1.5-2 years intervals, nothing to worry though.
Honda Accord 2008 EX-L 2.4 S
aguilarpro
Member - Posts: 45
Posted: June 18, 2019 at 10:17 PM / IP Logged Link to Post Post Reply Quote aguilarpro
I watched your video. You have the exact same problem as with the link I shared the post prior, just read on this post and you will find that you are in the same situation as I was where you get 7 (flashes) [or clicks]. https://www.the12volt.com/installbay/forum_posts.asp?tid=139588
