Check Engine Light, Viper 4806v, 2017 Nissan Rouge
mhunguyen
Member - Posts: 32
Posted: November 30, 2019 at 1:48 PM / IP Logged Link to Post Post Reply Quote mhunguyen
Hello. Been a long time member of this forum and have installed many Viper Starters with the help of this community. I am having an issue with a current viper install on a Nissan Rouge 2017 using D2D ADS ALCA. Everything seems to be working, but having an issue with the check engine light on once the rs starts.
Not sure what happened, but can’t seem to get rid of the light any help is much appreciated.
mhunguyen
Member - Posts: 32
Posted: November 30, 2019 at 3:42 PM / IP Logged Link to Post Post Reply Quote mhunguyen
Code reads P0463.
silvercivicsir
Copper - Posts: 416
Posted: December 02, 2019 at 11:24 AM / IP Logged Link to Post Post Reply Quote silvercivicsir
does the check engine light come when you do a key start? If it doesn't I would recheck your wires, you have have tagged an incorrect wire.
mhunguyen
Member - Posts: 32
Posted: December 02, 2019 at 4:09 PM / IP Logged Link to Post Post Reply Quote mhunguyen
It does come on when i do a key start. So i'm wondering if some of the pins came loose when I did the wiring.
97f150ext
Copper - Posts: 104
Posted: December 10, 2019 at 4:52 PM / IP Logged Link to Post Post Reply Quote 97f150ext
I recently installed a Avital 4105 with a Fortin Evo-All and used the THAR-NIS3 T harness. I, too, experienced check engine lights and random other lights, upon starting the car after the installation. I found the green connector at the BCM was causing the issue. In my case, the T harness being used was the issue. However, if you do not have the proper connections at the green connector, you will trip the check engine light. I cannot speak to your specific issue, but maybe my problem will shed some light for you.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
