2015 Subaru Impreza, Avital 4105
avrohom24
Member - Posts: 31
Posted: May 23, 2020 at 9:10 PM / IP Logged Link to Post Post Reply Quote avrohom24
In stalled the Avital 4105l with a key in the box bypass in a 2015 Subaru Impreza. Programmed the remote and it locks/unlocks the car. But the remote start doesn't even attempt to crank even with the keychip in the ignition. Any ideas?
ays
silvercivicsir
Copper - Posts: 416
Posted: May 24, 2020 at 12:11 AM / IP Logged Link to Post Post Reply Quote silvercivicsir
blk/white grounded? hook up and learn tach ?
avrohom24
Member - Posts: 31
Posted: May 24, 2020 at 12:13 AM / IP Logged Link to Post Post Reply Quote avrohom24
yes
ays
avrohom24
Member - Posts: 31
Posted: May 24, 2020 at 12:15 AM / IP Logged Link to Post Post Reply Quote avrohom24
sorry, didnt see the second part of your post. Tach was not, but it wont even try to crank. Im going to try the tach , but I thought that if it didnt even try, its something else
ays
geepherder
Platinum - Posts: 3,668
Posted: May 24, 2020 at 7:51 AM / IP Logged Link to Post Post Reply Quote geepherder
Is this a manual or automatic transmission vehicle?
avrohom24
Member - Posts: 31
Posted: May 24, 2020 at 8:40 AM / IP Logged Link to Post Post Reply Quote avrohom24
Automatic
2 things may give a clue.
1)I left the car overnight and in the morning the battery was dead
2) I don't get any reading on the multi-meter for the starter and ignition wires when I try the remote starter, although I do get when using the regular car key
Thank You for the help
ays
geepherder
Posted: May 24, 2020 at 9:04 AM / IP Logged Link to Post Post Reply Quote geepherder
Do you have both red power wires connected in the remote start harness? Are both the 30 amp fuses good?
avrohom24
Member - Posts: 31
Posted: May 24, 2020 at 9:23 AM / IP Logged Link to Post Post Reply Quote avrohom24
yes, tested the with a multimeter
ays
geepherder
Posted: May 24, 2020 at 9:46 AM / IP Logged Link to Post Post Reply Quote geepherder
You could try doing the shutdown diagnostics. Since it's a one-way system, you wouldn't get an error from the remote.
Say for example, it gives a brake shutdown. Disconnect your connection to the brake wire and see if it remote starts then.
avrohom24
Member - Posts: 31
Posted: May 24, 2020 at 9:51 AM / IP Logged Link to Post Post Reply Quote avrohom24
will do, thanks
ays
Page of 5
Thursday, October 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
