Does The 12V Wire Need To Be Constant?
josephc04
Posted: June 15, 2020 at 7:41 PM / IP Logged Link to Post Post Reply Quote josephc04
Currently looking to install a Viper 4105 in my 2009 Ford Escape. There are two wires on the remote start harness that show they should be connected to a "(+) (30A) HIGH CURRENT 12V INPUT". Should that wire be a 12V constant, or should it only supply 12V when the ignition is in the run or on position?
Thanks in advance.
Platinum - Posts: 7,827
Posted: June 15, 2020 at 7:56 PM / IP Logged Link to Post Post Reply Quote kreg357
Must be constant. This constant power allows the system to be ON awaiting commands from the Viper 4105 remotes.
