dodge viper - wiring diagram
naughtydog
Copper - Posts: 90
Posted: July 25, 2002 at 3:27 AM / IP Logged
I am desperate for a wiring diagram for an alarm install on a Dodge Viper T10 - 2002 model.
I am in the UK so have very little access to info other than you through you great guys.
Thanks a lot
Naughtydog
Platinum - Posts: 12,488
Posted: July 25, 2002 at 5:21 AM / IP Logged
|              12V|red & pink/black    |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|blue                |+  |ignition harness            |
|        ACCESSORY|BLACK/ orange        |+  |ignition harness            |
| SECOND ACCESSORY|BLACK/ white         |+  |ignition harness            |
|       POWER LOCK|WHITE/ green *1      |+  |lt blu plug,pin D14 @ EEM *2|
|     POWER UNLOCK|same wire           |   |                            |
|       LOCK MOTOR|                    |   |                            |
|     UNLOCK MOTOR|                    |   |                            |
|    DISARM DEFEAT|                    |   |                            |
| PARKING LIGHTS +|BLACK / YELLOW *3     |   |grn plug, pin B @ EEM *2    |
|       HEADLIGHTS|lt GREEN/ red        |+  |headlight switch            |
|     DOOR TRIGGER|*4                  |-  |lt blue plug @ EEM *2       |
| DOME SUPERVISION|yellow              |-  |grn plug,pin 6,under fusebox|
|  TRUNK/HATCH PIN|gray/black(GTS only)|-  |lt blu plug,pin C14 @ EEM *2|
|         HOOD PIN|BROWN / tan           |-  |lt blu plug,pin C12 @ EEM *2|
|  FCTRY ALARM ARM|arms with lock *5   |   |                            |
|FCTRY ALRM DISARM|lt GREEN/ orange     |+  |lt blu plug,pin C11 @ EEM *2|
|       TACHOMETER|gray/lt blue        |   |gry plug, pin 31 @ PCM *6   |
|      SPEED SENSE|WHITE/ tan           |   |radio                       |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|BLACK/ red           |-  |lt blu plug, pin C3 @ EEM *2|
|           WIPERS|brn/wht(L),RED / yel(H|-  |steering column             |
|  LF WINDOW UP/DN|lt blue - white     |A  |switch on center console    |
|  RF WINDOW UP/DN|brown - purple      |A  |switch on center console    |
|        RADIO 12V|pink                |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|RED / white           |+  |radio                       |
| RADIO ILLUMINATE|BLACK / YELLOW        |+  |radio                       |
|    POWER ANTENNA|GREEN/ red           |+  |radio                       |
|       LF SPEAKER|lt grn/pu-lt grn/grn|   |power amplifier *7          |
|       RF SPEAKER|lt blu/pu-lt blu/grn|   |power amplifier *7          |
|       LR SPEAKER|wht/pur - wht/grn   |   |power amplifier *7          |
|       RR SPEAKER|tan/pur - tan/grn   |   |power amplifier *7          |
Notes:
*1 Pulse the wire once will lock the doors and pulsing it again will unlock the doors. To OPEN the driver door pulse positive to pink/white in pin D11, in the lt blue plug of the EEM. To OPEN the passenger door pulse positive to ORANGE / white in pin D12.  *2 The EEM (Electronic Entry Module) is located on the driver side of the transmission tunnel.  *3 Also found tan at the headlight switch.  *4 The driver door trigger is BLACK/ lt blue in pin C15, and the passenger door trigger is tan/red in pin C16. Use both wires and diode isolate each.  *5 The factory alarm will arm with lock if it see the driver door open. Use the lock output to pulse the driver door trigger the same time as lock.  *6 The PCM (Powertrain Control Module) is on the driver fender under the power distribution center. The tach wire is also located behind the instrument cluster.  *7 The power amplifier is located on the driver side of the trunk.
naughtydog
Copper - Posts: 90
Posted: July 25, 2002 at 5:30 AM / IP Logged
Cheers Jeff.
Do you know of an immobilisation point other than the starter. I think it has twin fuel pumps.
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
