directstart cs423
Koolaid421
Member - Posts: 22
Posted: March 02, 2004 at 3:40 PM / IP Logged
has any body used 1 of the remote starts on there vehicle. i am having problems with this i cant get it to work i have all the wires hooked up correctly i think pls help its on a 2001 ford f150
hell yea
cbag1
Copper - Posts: 59
Posted: March 02, 2004 at 4:44 PM / IP Logged
i installed this unit to my grand caravan 2003 it works great.
tell me whats wrong i might can help.
Moderator - Posts: 12,488
Posted: March 02, 2004 at 4:54 PM / IP Logged
Post your wire colors that you used and we can better troubleshoot for a solution. IT's probably an IGN or ACC wire that you need to power up or it's the bypass module that you used that is not programmed or the key is not in the right position.
Koolaid421
Member - Posts: 22
Posted: March 02, 2004 at 5:01 PM / IP Logged
remote start                                                            truck
acc        green        gray / YELLOW
                red (2)                                                           yellow (2)
ignition          blue                                                        dark blu/green
lets start with these
hell yea
Koolaid421
Member - Posts: 22
Posted: March 02, 2004 at 5:03 PM / IP Logged
i think i might be having problems with the hood pin and door switches but i have no idea
hell yea
jrilla
Gold - Posts: 1,498
Posted: March 02, 2004 at 5:34 PM / IP Logged
Does anything work at all? Did you hook up the parking light output? If so, do the lights flash at all when you try to remote start, or when you press lock or unlock? How are you bypassing the immobilizer? More information that is clearly presented and perhaps a paragragh describing in detail what is working, not working, or any other information you can think of would make troubleshooting much easier for anyone interesated in helping.
J Rilla
Owner/Installer
Koolaid421
Member - Posts: 22
Posted: March 02, 2004 at 5:44 PM / IP Logged
ok the parking lights work but when i try to progam the tach the lights turn on then turn off but i dont get the 2 fast and 2 slow like its says i should. i am using a cut off key to bypass and i know that it works because the truck will start with it.
hell yea
jrilla
Gold - Posts: 1,498
Posted: March 02, 2004 at 6:00 PM / IP Logged
Where did you find your tach source? you may need to find a new tach source. Also make sure you are programming it when the engine is warm and try turning the fans on, and whatever else to lower the RPM's.
Tach wire:
on the 4.2L it is a dk. blue/lt. green at the coil pack on top of the motor.
On the 4.6L go to any of the 8 ignition coils and use the wire that is not RED / green.
On the 5.4L it is a lt. GREEN / WHITE at the coil on the passenger side of the motor between the fuel injectors.
J Rilla
Owner/Installer
Koolaid421
Member - Posts: 22
Posted: March 02, 2004 at 6:13 PM / IP Logged
ok that is where i had it first and it was doing the same thing so i moved it to the injector wire
hell yea
Posted: March 02, 2004 at 6:22 PM / IP Logged
Is this a manual transmission vehicle ??
Wednesday, July 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
