Viper 790XV Remote
nei00755
Copper - Posts: 61
Posted: April 14, 2004 at 2:05 PM / IP Logged
I recently had some body work done to my car......that's beside the point.....but during that time the car died and they had to charge it on me twice.....well since then my remote will not commmunicate with the remote start\keyless entry module.  I thought possibly a fuse was blow but I did a tach learn and that worked no problem.  I think possible somehow the remote and brain got screwed up and need to be relearned, and I do not have my owners manuel, so if anyone can post instructions on relearning my remote to my brain, that would be great.  THanks
Teamrf
Gold - Posts: 1,031
Posted: April 14, 2004 at 2:32 PM / IP Logged
You may want to see if the antenna is still plugged up to the alarm. You can also go to www.directed.com and get the installation manual for that alarm.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
nei00755
Copper - Posts: 61
Posted: April 14, 2004 at 3:07 PM / IP Logged
I checked my antenna and that wasn't it.  I already downloaded the manuel and that didn't say anything about programming remotes....unless I am blind, which is possible
nei00755
Copper - Posts: 61
Posted: April 14, 2004 at 3:14 PM / IP Logged
I think I downloaded the owners guide instead of the install guide, I will  have to check that out
nei00755
Copper - Posts: 61
Posted: April 14, 2004 at 3:22 PM / IP Logged
Ok, that did not work either, I found the learning instructions but they did not work, I wonder if the remote is junk
CutDog504
Silver - Posts: 643
Posted: April 14, 2004 at 4:06 PM / IP Logged
I had a friend that had a 790 do the EXACT same thing. I tested all the wiring and even the remote start. All was fine. I even tried reprogramming the remote, no luck. I concluded it was a bad remote. We programmed a 791 remote, and it worked fine. The shop where he bought the 791 remote says that happens ALL the time. He said the 790 remotes are notorious for going bad. He said He even thinks DEI had a recall on them. I know this much, just a few months after releasing the 790, viper discontinued it and replaced it with the 791. What does that tell you?
nei00755
Copper - Posts: 61
Posted: April 14, 2004 at 4:36 PM / IP Logged
It just seems weird that it happened right after my car went dead
nei00755
Copper - Posts: 61
Posted: April 14, 2004 at 4:45 PM / IP Logged
It is just kind of weird that it all of a sudden happened when the car was dead and they had to jump my car
kgerry
Platinum - Posts: 3,455
Posted: April 14, 2004 at 6:21 PM / IP Logged
not really... a power spike would easily account for a problem like that... the reciever is in the antenna unit itself... so try unplugging it both from the brain and from the antenna and see if it will reset... also pull all the fuses from the unit and leave it powered down for about 15 minutes and then put the fuses back in and see what happens...
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
sroth140
Silver - Posts: 513
Posted: April 15, 2004 at 12:59 AM / IP Logged
i still try to tell people to unplug both ends of the antenna then plug them back in.  its fixed a few cars in my bay.  no real reason it just works.  kinda like kicking your tv.
MECP certified installer
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
