2005 Altima (3.5)
brianh
Silver - Posts: 518
Posted: July 31, 2004 at 7:07 AM / IP Logged
I have a customer who is wanting me to do a R.S install on this car next week. I was just wondering if anyone has any info on this new of a vehicle? If so please post it and I will be forever greatful. Thanks alot.
Brian
owner/installer
Sight & Sound Car Stereo
"all electronic equipment runs off of smoke, once you let it out, it stops working"
Platinum - Posts: 12,488
Posted: July 31, 2004 at 9:02 AM / IP Logged
12volts green (40A)  +  ignition harness
Starter BLACK/ red  +  ignition harness
Second Starter BLACK / YELLOW  +  ignition harness
Ignition BLACK/ red  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory red  +  ignition harness
Second Accessory WHITE/ blue  +  ignition harness
Keysense BLACK/ red  +  ignition harness or BCM, pin 37
Power Lock brown  -  BCM to right of fuse box, pin 45
        Notes: These wires are only available on vehicles with left front only power window anti-pinch system. On vehicles with left AND right front power window anti-pinch system, use the factory alarm arm and disarm wires for door locks.
Power Unlock :  pink  -  BCM to right of fuse box, pin 46
Lock Motor yellow/red  5wi BCM to right of fuse box, pin 65
Unlock Motor GREEN / WHITE  5wi BCM to right of fuse box, pin 59
Parking Lights+ RED / blue  +  driver kick, harness to rear
Parking Lights- N/A
Hazards GREEN/ red  -  BCM to right of fuse box, pin 29
Turn Signal(L) GREEN/ black  +  BCM to right of fuse box, pin 60
Turn Signal(R) GREEN/ YELLOW  +  BCM to right of fuse box, pin 61
Reverse Light GREEN / WHITE  +  driver kick, harness to rear
Door Trigger see notes  -  BCM to right of fuse box
Notes: The LF door is lt. blue in pin 47, RF door is pink/blue in pin 12, LR door is RED / black in pin 48, and RR door is RED / white in pin 13. Use all four wires and diode isolate each.
Dome Supervision red  -  BCM to right of fuse box, pin 63
Trunk/Hatch Pin PURPLE / white  -  BCM to right of fuse box, pin 42
Hood Pin N/A
Trunk/Hatch Release RED / black or blue/red  -  BCM to right of fuse box, pin 30
Power Sliding Door N/A
Factory Alarm Arm pink/blue  -  driver door module in door, pin 4
Notes: Meter this wire while turning the key in the driver door key cylinder.
This wire will also lock the doors.
Factory Alarm Disarm WHITE/ blue  -  driver door module in door, pin 5
Single pulse on this wire will disarm the factory alarm, and double pulse will unlock the doors.
Disarm No Unlock see factory alarm disarm
Tachometer NOT red, pink, or black  ac  any ignition coil or fuel injector
Wait to start N/A
Brake Wire RED / green  +  brake pedal switch
Parking Brake green  -  parking brake switch
Horn Trigger GREEN / WHITE  -  steering column
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
