1991 Ford Probe LX
jamac010
Member - Posts: 7
Posted: October 14, 2004 at 7:59 AM / IP Logged
Im trying to install an alarm system.  I need to lock and unlock the doors.  I found that this car had a single wire that locks when 12V+ is applied and unlocks with 12V+ through a 4.7K ohm resistor from the link below.
https://www.the12volt.com/doorlocks/page2.asp#fp
However my alarm has positive outputs from the alarm with the lock and unlock.  Can someone clairify how to do it?  Theres a diagram but for negitive alarm outputs.
James
mo12v
Posted: October 14, 2004 at 8:20 AM / IP Logged
If U have + (positive) Outputs from Alarm, hook Lock wire to the GREEN/ Black   and the UNLock wire to 4.7k resistor, then hook that also to the GREEN/ Black
or
Use Positive Pulse thru 2 SPDT Relays
Power LockGREEN/ BLACKSINGLE WIRE
Power UnlockGREEN/ BLACKSINGLE WIRE *
Single Wire Resistor Door Locks
. * Single Wire Door Lock System. GREEN/ BLACK Wire Requires A 12 VDC (+) Pulse To Lock Doors And A 12 VDC (+) Pulse Thru A 4.7K Ohm Resistor To Unlock.
MO
jamac010
Member - Posts: 7
Posted: October 14, 2004 at 10:09 AM / IP Logged
Yes that would work however.  The alarm supplys a constant +12VDC until the remote is pressed. Then the volts drop to 0 for a brief moment.  I need to hook it up to relays but want to know how it is different then the diagram from the link which has negative triggers.
James
huntersdad
Member - Posts: 9
Posted: October 14, 2004 at 10:21 AM / IP Logged
does the alarm go to 0 volts or to ground.... put your meter on conitnuity and see when u unlock or lock if the meter has a beeping sound if it does then follow the diagram u found
u ever flew on the ground?
Platinum - Posts: 12,488
Posted: October 14, 2004 at 12:45 PM / IP Logged
What kind of system do you have? From the sounds of things the unit has alternating polarity door lock outputs.
jamac010
Member - Posts: 7
Posted: October 14, 2004 at 1:35 PM / IP Logged
I have a Option group.  One of those cheap ones from ebay.
jamac010
Member - Posts: 7
Posted: October 14, 2004 at 4:51 PM / IP Logged
Ok I set it up with relays like the one in the links..Lock works but unlock doesnt.  I found that alarm grounds as if you put a ground wire to the terminals the car and unlock perfect.  I think there maybe something wrong with the alarm module itself.  I think both the lock and unlock wires from the alarm used to put out +12VDC.   Now the lock is putting out 12v and the unlock 1.5v.
When testing those with a multimeter the lock with drop to 0v (ground) and the unlock with stay at 1.5v constant.
Think I somehow messed up the alarm unit with testing wires?
James
