Autopage 750 Shock Sensor ?
sdsviet
Member - Posts: 12
Posted: October 23, 2004 at 9:27 PM / IP Logged
hey i was wondering how come the shock sensor on the 750 cant be mounted upside down? it said something about impossible to adjust. i actually got it mounted upside down but i can still adjust the thing but i dont know if the sensitivity on it changed at all. my friends was like pushing my car around and kicking the tires and it didnt even go off. i had to really beat on the window for it to go off. so then i put the sensitivity all the way up but nothing changed. is it because its mounted upside down?
Teken
Gold - Posts: 1,492
Posted: October 23, 2004 at 9:59 PM / IP Logged
I would be leaning more toward to your placement, and how it was affixed to the vehicle.
Unless, you open the unit up and inside you find a suspended rubber band with a magnet, then you are indeed in for some erractic behaviour and fun.
The standard is peizeo electonic pick up.
Regards
EVIL Teken . . .
sdsviet
Member - Posts: 12
Posted: October 24, 2004 at 11:59 PM / IP Logged
so if i turned it right side up, it would be better off? my friend said something like if it had some type of mercury thing for the sensor then it needs to be right side up.
Teken
Gold - Posts: 1,492
Posted: October 25, 2004 at 3:39 PM / IP Logged
If the unit is using a mercury based material within, then yes you need to install the unit according to the makers directions.
Normally mercury switches are used as tilt sensors, but Ungo and a few other manufactures have employed mercury type sensors to detect impact as well.
You wont know untill you verify the unit with documentation, or by opening up the unit.
Regards
EVIL Teken . . .
sdsviet
Member - Posts: 12
Posted: November 11, 2004 at 12:53 AM / IP Logged
the documentation doesnt not say anyhting of wat the shock sensor is made of it just says do not mount upside cuz it will be impossible to adjust. it does not give reasons to why its impossible to adjust.
amador
Copper - Posts: 108
Posted: November 11, 2004 at 1:49 AM / IP Logged
the 750 has a shock sensor not a merc. i would try a new location . kicking the tire is a bad way to check for sensitivity after all yous have shocks that will absorb the shock
amador
Copper - Posts: 108
