02 expedition GEM wake up
Hymer
Silver - Posts: 695
Posted: January 25, 2005 at 1:33 PM / IP Logged
Anyone know where this wire is .. yell/black or black yell??? I think its in the dr kick, but I'v treid about every wire there with a - pulse and she won't wake up... anything??
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
KarTuneMan
Platinum - Posts: 7,056
Posted: January 25, 2005 at 1:47 PM / IP Logged
Its BLACK / YELLOW......its the drivers door pin @ the pcm.  You need to isolate this wire from the pcm.
Or "break" it with a relay.....Its set up like isolating a Dodge neg parking light wire. Look in the astrochart
You can also find the wire in the drivers door boot!
You can use your pulse before and after trigger wires on the same relay. One to wake up.....and one to shut off the radio after run time
Hymer
Silver - Posts: 695
Posted: January 25, 2005 at 2:39 PM / IP Logged
Thanks guy.. I appreciate it!!! it worked great...
Later
KarTuneMan
Posted: January 25, 2005 at 6:28 PM / IP Logged
KooL......
