car alarm arm's its while driving
tj69_00
Posted: April 28, 2002 at 10:22 PM / IP Logged
i've had a vampire car alarm 4040 model car alarm and remote starter combo installed in a 91 eagle talon last week. everything  was done by the book and everything, but when i disarm the alarm and take offf to drive the alarm will arm its a minute after i disarm it while i'm driving down the road.  when i disarm it i dont get the two chirm sounds i should get, just the flashes and thats it.  everything else works fine the remote starter works great.  what is their to do?
Platinum - Posts: 12,488
Posted: April 28, 2002 at 10:32 PM / IP Logged
Make sure that the ignition wire is properly connected and make sure that the switched ignition wire that you got from the Eagle was infact a switched power and not a constant. Another ting is to make sure that the automatic arm is programmed off, but I would check the ignition wire first.
scss
Member - Posts: 25
Posted: April 30, 2002 at 12:20 AM / IP Logged
Check
  • ignition wire for true ignition
  • Check your door trigers
