Remote Start , bypass the run time feature?
mexi
Copper - Posts: 156
Posted: April 07, 2005 at 10:43 AM / IP Logged
Does anyone know if it is possible to bypass the run time feature on a remote start. My customer needs for his vehicle to run indefinitly. He does not want it to shut off in an hour. Please any info is helpfull. Thank you.
mexicang
brcidd
Copper - Posts: 274
Posted: April 07, 2005 at 2:18 PM / IP Logged
The Crimestopper units have an infinity run time mode-- cars runs until it runs out of gas..........you hit the start button twice on the remote while it is running to set it to this..............
Brcidd - Engineer That Does Remote Starter Installs on the side.
mexi
Copper - Posts: 156
Posted: April 07, 2005 at 4:34 PM / IP Logged
I've already installed a DEI 561T. Is there any way to bypass the runtime feature on this model.
mexicang
auex
Platinum - Posts: 5,041
Posted: April 07, 2005 at 5:20 PM / IP Logged
No, and if he wants it disabled then he is an idiot. There is no reason that it needs it to run for any length more then a hour. If he needs it to run longer tell his ass to use his key. Don't forget that there are some states that have run time laws as well.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
the12volt
Administrator - Posts: 3,959
Posted: April 07, 2005 at 5:22 PM / IP Logged
You could always use relays to keep it running. Depending on how you want to wire it up, the number of relays needed could be as little as the number of ignition, accessory, and light leads you want/need to keep energized. Keep in mind you'll need to use an additional relay to reset it by pressing the brake or you could even use a momentary contact button/switch to reset it.
Remote Start , bypass the run time feature? -- posted image. the12volt • Support the12volt.com
mexi
Copper - Posts: 156
Posted: April 07, 2005 at 6:09 PM / IP Logged
The reason to keep it running is the vehicle carries a bomb sniffing dog. The vehicle is a 2005 Ford Excursion. You wouldnt happen to have a diagram on how to wire these relays, it would really help. I get really confused on relays. Thanks for the help.
mexicang
auex
Posted: April 07, 2005 at 6:22 PM / IP Logged
What equipment do you have in this vehicle? Mainly the alarm.
mexi
Copper - Posts: 156
Posted: April 07, 2005 at 7:05 PM / IP Logged
It is a DEI 561T along with a 555F bypass. It is activated by hitting lock 3 times
mexicang
mexi
Copper - Posts: 156
Posted: April 07, 2005 at 10:08 PM / IP Logged
Please i need help i'm doing the install tommorow.
mexicang
auex
Posted: April 07, 2005 at 10:17 PM / IP Logged
Ok, I got a way. Give me a couple minutes to think it out.
Page of 3
