98 accord rear defrost to clifford 3.5
accord78
Copper - Posts: 97
Posted: November 07, 2005 at 4:59 PM / IP Logged
sup guys how would i go on hooking up the rear defrost wire from the clifford matrix 3.5 to the switch for the rear defrost on this car???? 98 honda accord ex 4door/4cylinder
05gt
Silver - Posts: 628
Posted: November 07, 2005 at 7:51 PM / IP Logged
PIN 87 = (-) Defrost Switch in car
PIN 87a = Not used
PIN 30 = ground
PIN 85 = a negaive output from the alarm brain
PIN 86 = Constant power (+)
this should help you
accord78
Copper - Posts: 97
Posted: November 07, 2005 at 8:48 PM / IP Logged
thanks for the fast reply.... 1 more thing where and what color is the wire at the switch i need and would i be using the blue/white (-) 200ma 2nd status/defogger wire from the 3.5 brain???   so it would be
pin87= - at switch
pin87a= not used
pin30= ground
pin85= blue/white deffoger wire from 3.5
pin86=constant power
is this correct?????????
05gt
Silver - Posts: 628
Posted: November 07, 2005 at 9:00 PM / IP Logged
I used a (-) aux channel from my alarm
you will have to fet behind the defroster switch in the car and do some testing with a DMM (multimeter)
but the relay is right
