Window module and pulse timer 528t
wester97
Member - Posts: 32
Posted: November 19, 2005 at 5:39 PM / IP Logged
I've been searching the forums for the answer to this, but was unable to find it.  This is probably one of the easiest uses of these parts, but I want to make sure I understand everything before I operate.
I am going to trigger the pulse timer off of the factory keyless entry system (the wire which corresponds to the lock/arm function) The pulse timer will send a signal to the widow module to roll the windows up.
The only part I am really confused on is the pulse timer wire configs.
  Which wires do i connect to the window module.  I know how to use the +/- and trigger but here are the others:
    Orange 87A (normally closed)
    Brown 87B (normally open)
    Yellow 30 Common
My assumption is that i will use the orange, but what does the common do?
Thanks in advance for your help!!!
cntrylvr79
Silver - Posts: 582
Posted: November 19, 2005 at 6:38 PM / IP Logged
First you'll need to find a wire in the car that either goes to ground momentarily when you lock the doors, or goes to +12volts.  Then, the BLACK/ white wire from the 528t will goes to that wire.  The red off the 528t goes to constant +12volts.  Black and Brown both go to ground.  Finally Yellow gets hooked up to that tiny orange wire off the window controller.  As for the blue loop, if the wire in the car that switches goes to ground then leave it alone.  If it goes to +12volts then cut it and isolate the ends.  The orange wire on the 52t you will not need.
Cause I'm So white and nerdy...
First Class Certi-fried installer
wester97
Member - Posts: 32
Posted: November 19, 2005 at 6:42 PM / IP Logged
You rock - I'll let you guys know how it goes.
wester97
Member - Posts: 32
Posted: November 19, 2005 at 6:50 PM / IP Logged
oh, and also - what is the easiest way to use a multimeter to test all of these wires?  Do i have to find a point of termination and test there?   or is there an easier way
KPierson
Platinum - Posts: 3,527
Posted: November 19, 2005 at 8:18 PM / IP Logged
Whats the make/model/year of the car?
You can typically strip back the wire at a point its easy to test.  If its not the right wire just wrap some electrial tape around where you broke the insulation and move on.
Kevin Pierson
wester97
Member - Posts: 32
Posted: November 19, 2005 at 9:13 PM / IP Logged
it is a 2001 Nissan Pathfinder.
wester97
Member - Posts: 32
Posted: November 19, 2005 at 9:36 PM / IP Logged
I am supposed to use the Brown (the normally closed).  Does this mean that it should go to activate a circuit that is normally closed?  I'm kinda confused.
wester97
Member - Posts: 32
Posted: November 20, 2005 at 1:10 AM / IP Logged
is this true with this?:
When the coil of the relay is at rest (not energized), the common terminal (30) and the normally closed terminal (87a) have continuity. When the coil is energized, the common terminal (30) and the normally open terminal (87) have continuity.
rsudbay
Copper - Posts: 68
Posted: November 20, 2005 at 10:45 AM / IP Logged
hey man, it sounds like you are mostly having relay problems, have you looked at the relay page on this web site. it will help a hell of a lot. https://www.the12volt.com/relays/relays.asp   good luck
hey, everyone has got to start somewhere. but ill learn
iskidoo
Silver - Posts: 1,048
Posted: November 20, 2005 at 12:42 PM / IP Logged
Yes this is true for the 528T. It is basically a standard relay but with an adjustable timer on it. It functions the same as what you described. It holds the connection open or closed for 1-90 seconds. The common you asked about is a wire that is common to both the open and closed wire. You always hook one side of the wire your connecting or disconnecting to it. The other side of the cut wire goes to either the normally open or normally closed wire. If you want to supply the yellow window module input trigger wire with a ground for a period of time. You hook the common to ground and the yellow wire to the normally open wire. This way when the timer is triggered by the lock the adjustable timer triggers the window module wire for the amount of time it needs to roll up all the windows and then disengages the trigger wire after the timer elapses.
Steve G
Page of 3
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
